Help w/ Eye Diagrams and Mask Tests
I could use some experienced help here 🙂
So i have a scope capture of a representative signal that will be used in this VI.
I have several problems which i could use some help with.
1) Trying to create an EYE diagram out of this waveform.  Because it is repeating i have already have the algorithm to chop it up into seperate 'waveforms', how would i go about displaying something like this as an eye diagram with the LV graphs?  I have tried everything i can think of, i cant just use build waveform or hardwire anything because the # of Voltage arrays will differ every time in real usage.
What i did is create a waveform chart, i build a waveform type w/ dt and the Y values and plug it in.  I was hoping to use the 'scope' setup as from the description in help seemed to do what i wanted, but it does not seem like it overlays onto the graph.
Basically i need a way to create a multiplot graph from X,Y coordinates and dynamically increment the number of plots until its done. Hopefully that makes sense.
2) Eventually i also need to do a multi part mask test on this 'infinite persistence' signal if you were.  This shouldnt be too hard as i will have the arrays of voltage at my disposal from above that i can loop through.  My question regarding Mask tests is this, for this particular mask test there are 4 actual masks.  An upper & lower and 2 'eyes' that it must clear, it seems LV's express mask testing only lets you do a top/bottom mask.
What would be the best way to do mask tests like this?  Use the express VI and split it into 2 parts and 'and' them together?  Or would doing it more manually with some of the non express mask stuff prove to be easier?
I got many more questions but i'll stick with that for now 🙂  Thanks in advance!
Message 1 of 10
(4,058 Views)
I would be happy to help you, though I may need some of your code to show you how I did it.  I am trying to track down the code i used for an eye diagram VI.
Basically for graphing it I would suggest an intensity graph.  It leads to really nice graphs that have the persistance.  The challenge is deciding how to scale the intensity ranges.  I did not use an XY because you get a lot of overlaid plots, but not the intensity of how often a value was hit.
I imagine you will need to write some custom mask code, but yo-u may be able to see hwo teh express blocks did the test to get some good idea.  Attach what you have and we can go from there.
Message 2 of 10
(4,049 Views)
Yea any help you can give would help..
Message 3 of 10
(4,034 Views)
I am really confused when it comes to Intensity charts/graphs, it doesnt seem to want to actually graph the x,y coordinates that i put in..can it be used for that(Similiar to infinite persistence on a newer scope).
Message 4 of 10
(4,029 Views)
Take a look at this example.  You can see where I am creating the waveforms you would obviously use your files there.
Message 5 of 10
(4,021 Views)
Doh im still working in 7.1..is there any way you can downgrade it for me to take a looksy?
Message 6 of 10
(4,019 Views)
Hmmm well hopefully you read this thread again because i cant open those files and i have a feeling they could help alot..
We do own 8.2 but our current SW is 7.1 so i dont want to upgrade and cause possible conflicts...
Message 7 of 10
(4,004 Views)
Here they are... Note that in the SubVI I use an interpolate 1d that is available in 8.0.  I do that to stretch the points out some.
Message 8 of 10
(3,985 Views)
Well that sort of helps, atleast in learning how the intensity graphing works.
The biggest hurdle i have is making a signal 'loop' over itself.
So i have this long aquisition in X,Y coordinates in a txt file.  It is a long sequence of semi random data.  What i need to do is chop that data up into 115ns portions, and stack those on top of eachother.  The problem is i am not sure what the best method to do this is, because the number of sections that get created from this chop up probably wont always be the same.
Message 9 of 10
(3,979 Views)
Go ahead and attach any code you have already started working with and an example txt file.  We cna then look at that.
Message 10 of 10
(3,963 Views)
