Help with Channel Wizard
i am experiencing measurements with multiple transducers. And the hardware that i have is :
SCXI-2000 chassis
SCXI-1200 module
SCXI-1121 and a SCXI-1321 terminal block.
When i am reading from a single one strain gauge transudcer in the channel 0 that is no problem . it works on whatever vi, but the problem occurs when i put the second sensor in the channel 1. It seems the Channel Wizard (LabVIEW 5.0 / NI-DAQ 6.1) don't recognize anything, and i got lost the values that were read from channel 0. it simply does not work anymore.
I am using the multiplexed operating mode, but i am not sure.
It is possible to measure multiple sensors with the SCXI-1200 in paralel mode ?.
i will have to just acquire scans from about 4 sensors: pres
sure, vibration, flow, temperature. But i just can do it with a single one !
Anyone help please.
Jose Luiz
Message 1 of 1
(2,710 Views)
