Help with Datalogging.....How to edit my datalog fle?
I have a FFT Program that creates a datalog file.  Once the file is created, I have another program to recall that info for viewing only.  I need to recall the datalog file and then Edit the file, and save or save as to it.  I have included 3 programs, the FFT analyzer(creates the file), the Read FFT Data program(original reader, cant edit here), and my best shot at getting this done(EDITED porgram).  I appreciate any help, Thank you,  I basically just need to edit the datalog file.
Jeff
(2,464 Views)
Hi Jmc006,
I am not exactly sure what you want to do, but I will give it a stab.
It seems that you are pretty much reading a file and writing certain information from it to another data log file, with additional edits.
If this is so, all you need to do is put it into a sequence structure like the original read and place the write in a while loop, like the example "Write Datalog File Example.vi"
It seems like you're almost there. Hopefully this helps!!
Aashish M
CEO
TransferFi
www.transferfi.com
(2,436 Views)
