Help with Filtering an Array Using Standard Deviation
Hi everyone,
I'm working on a project where I receive an array of values ranging from 0.01 to 100,000. The issue is that the array sometimes contains some noise (electronic artifacts). My goal with this VI is to filter the array and create a new one that only contains values close to each other, based on their standard deviation.
However, for some reason, the result isn't what I expected. I’ve attached my VI to this post. Could someone help me figure out what I might be doing wrong or point out improvements I could make?
Here's a summary of what I'm trying to do:
  1. Filter out noise from the array.
  2. Keep values that fall within a specific range (calculated using the standard deviation).
  3. Output the filtered array for further processing.
If you need any additional information about my approach or the data I'm working with, feel free to ask. I’d appreciate any insights or suggestions!
Thanks in advance for your help!
Message 1 of 13
(4,902 Views)
You did not tell us what you expect.
Should the new array be shorter, missing the stray values?
Should the new array be the same size, but having stray value replaced based on neighbors?
There are many confusing points in your VI:
  • airing [i] to index array is the same as autoindexing.
  • Taking the sum only needs to be made once, because the result never changes.
  • Your feedback node makes little sense
I'll try to figure it out...
Message 2 of 13
(4,897 Views)
For example if you only want to keep values that are withing 100 of the mean, here's one possibility:
Message 3 of 13
(4,889 Views)
Thank you for your response, and I apologize for leaving things unclear.
What I want is for the array to be filtered so that only the values close to each other remain.
Here's an example of the type of array I receive:
0; 1; 0; 2; 0; 3; 0; 5; 0.1; 6; 0.1; 7; 0.11; 8; ...
And then it goes back down:
7; 0.2; 6; 0.1; 5; 0.1; 4; 0.1; 3; 0.2; 2.
What I want is for the resulting array to look like this:
1; 2; 3; 4; 5; 6; 7; 8; 7; 6; 5; 4; 3; 2; 1.
The issue is that I couldn’t organize the VI in a way that accomplishes this properly. That's why I'm seeking your help. I’m trying to use standard deviation to identify and filter out the noise, but the logic in my VI isn’t giving me the expected result.
Any guidance or suggestions to organize the VI better would be greatly appreciated. Thank you for your patience!
Message 4 of 13
(4,887 Views)
Thank you for your response, and I apologize for not being clear.
The main issue is that I receive a wide range of values, from 0.01 up to 10,000, but the array often includes problematic patterns like:
100; 0.1; 101, which causes significant errors when trying to organize the data properly.
What I’m trying to do is filter out the noise and get a clean array where only the relevant values remain, organized in ascending and descending order (depending on the incoming data).
For example, if the raw array looks like this:
100; 0.1; 101; 0.1; 102; ...,
I want the output to look like:
100; 101; 102; ...
I’ve been trying to use standard deviation to detect and remove outliers, but my VI doesn’t seem to handle this correctly. I think there’s a problem with how I’ve implemented the logic, and I’d really appreciate some help to fix it.
Thank you for your time and assistance!
Message 5 of 13
(4,883 Views)
In all your examples, it seems that the elements with odd or even index are bad. If this is not true, please provide a more realistic example.
Else you could just decimate the array:
Please attach your VI making sure that the input array has typical default values. Also tell us what you expect as result.
Message 6 of 13
(4,874 Views)
100; 101; 102; ...
Standard Deviation alone can't get you there with that kind of data set.   The bunch of values near 0.1 carry just as much weight as the bunch of values nearer 100.  You aren't doing enough to *discriminate* between the reasonable and the unreasonable values.
Where's this data coming from?  Why are you getting garbage values for (apparently) 1/2 the data?  Can you fix this at the source end rather than the destination?
When you, as a human, look at your data set, *exactly* how do you think through which values are reasonable and which are unreasonable?  Where do your expectations come from?  Can you translate that thought process into a different algorithm than a mere standard deviation?
-Kevin P
Message 7 of 13
(4,857 Views)
Thank you for your patience. I was finally able to set up the machine, and I’ve updated my VI to better illustrate the issue I’m facing.
The problem boils down to dealing with two arrays:
  1. The first array contains the value I’m looking for (60) along with electronic noise (e.g., 0.64).
  2. The second array behaves similarly, with the value I want (1.887) and the accompanying noise (e.g., 0.0128).
I’ve attempted to create a VI that uses standard deviation to filter the array, aiming to retain only the values that are close to each other while removing the extremely low noise values that are being transmitted alongside the desired data.
Despite my efforts, the result isn’t working as expected. The noise values still persist in the array, and the logic doesn’t seem to properly isolate the desired values.
I’ve attached my updated VI, where you can see:
  • The raw data as it comes from the machine.
  • My attempted filtering approach using standard deviation.
If anyone can help me refine the VI or suggest a better way to tackle this, I’d be very grateful. Thank you for your time and support!
Message 8 of 13
(4,833 Views)
Accepted by topic author MarcusP.
Your two arrays just differ by a factor of 50, which seems redundant.
As you can see, a simple decimation, keeping the even indices, is all you need.
Message 9 of 13
(4,811 Views)
Thank you so much for the help! It was really that simple... I can't believe I was struggling with something so straightforward, but your guidance made all the difference.
I’ve implemented the solution, and it’s now working perfectly. I really appreciate the time and effort you all put into helping me out. This community is amazing!
Thanks again!
Message 10 of 13
(4,801 Views)
