Help with Kvaser CAN bus interface
You can also look at Hooovahh's CAN blog
https://hooovahh.blogspot.com/2017/03/can-blog-introduction-and-downloads.html
It has drivers for Kvaser.
Message 11 of 15
(284 Views)
@dkfire wrote:
And how is that lib call setup ?
SAme as the others except this on is set to run in the UI thread instead of any thread
=== Engineer Ambiguously ===
Message 12 of 15
(279 Views)
@RTSLVU wrote:
I don't know what this is telling me.
Probably a mistake on my part somewhere. Probably the two integers need to be static (or const, or both). Since we saw that the dll can be called from within 32bit LabVIEW, I think there's not much diagnostic value left in determining if the dll itself is working properly.
For completeness, I guess this should work
cd "C:\Program Files (x86)\Kvaser\Canlib\Bin\"
function Can-InitializeLibrary{
    $Signature = @"
[DllImport("canlib32.dll", EntryPoint = "canInitializeLibrary")]
public static extern void canInitializeLibrary();
public static void InitLibraryExport() {
    Add-Type -MemberDefinition $Signature -Name InitLibraryType -Namespace User_
    [User_.InitLibraryType]::InitLibraryExport()
Message 13 of 15
(269 Views)
I need to check how mine is setup.
But you can try to change the Thread. Could be that is has loaded the lib in ui thread, and can't find it in the other threads.
Message 14 of 15
(260 Views)
Did a check on the working production code, that dll call is set to Any thread.
Message 15 of 15
(234 Views)
