Help with Labview school assignment
Hi i am a student currently doing my Labview assignment that is due tomorrow. but i just cant figure out how to make the front panel go like this. Can u guys help ?
the example is in below
(2,162 Views)
Hi i am a student currently trying to complete my school assignment that uses Labview. But i just cant figure out how to make to program goes like this.
Below is the youtube video example:
(2,154 Views)
Hi Johnny,
So you got an assignment and waited until now to even start to solve it? And now you want someone else to tell you how to solve it by tomorrow? (Is this the way students earn their points in these days?)
What have you tried so far?
Where are you stuck?
What did (s)he taught (aka "did you learn") about basic algorithms and program structures? (Independently from using LabVIEW or any other programming language!)
What did your teacher taught you about LabVIEW?
I recommend to use a statemachine!
LabVIEW comes with a pre-defined statemachine project, so you just need to
  • setup your frontpanel elements
  • embed your logic to switch on/off LED indicators
Edit after merging your threads:
Why do you think it is helpful/senseful to create two threads asking the same question in both of them?
(2,156 Views)
I guess you will fail that assignment and probably class. Apparently programming is not what you should be doing in the future.  Nothing wrong with that.
Maybe you could just create a basically empty VI where you embed that video into the front panel???
The code shown is pretty dumb and basically only has two states, depending in the value of the input. (... and the description "this is the example video how the program running for Test Assignment Task" does not help either, because it is completely meaningless.)
(2,101 Views)
