Help with Network Stream Reader URL configuration for 2 PCs on LAN
Hey, I'm new to LabVIEW and trying to get a network stream working between two PCs over LAN. I've attached the snippets for my writer and reader.
On the writer side, my endpoint name is 'writer' and on the reader side it's 'reader'. I'm entering the IPv4 address of the writer PC into the reader URL, but it’s still not working. Could someone please guide me and tell me if I'm missing something or if I'm entering the address incorrectly?
(821 Views)
remove the writer url from the reader. Remove the timeout from the reader.
Set the reader url for the writer instead. Can you ping the url?
If still not working check c:/system32/logs/firewall for dropped packages
CLA
(802 Views)
About a decade ago, I had a "Solution Accepted" for a Network Streams issue here .  See if it helps with your particular problem.  I continue to use the sub-VIs I wrote to configure the Readers and Writers, and it continues to work.
Bob Schor
(788 Views)
