Thank you for the several responses so far.
Its the strangest thing. We have used two different crossed cables, that we know are alright.
I can initiate an ftp session, and I can connect to the PXI machine using MAX or LabVIEW. With ftp, I can get directory listings from the PXI, and I can put data onto the PXI, but I cannot transfer data files from the PXI machine (ftp just hangs there waiting, and there is no traffic).
I was confident that my own LabVIEW TCP code was alright since the machines talk over the LAN, and this ftp test confirms that something strange is happening.
As I mentioned previously, the subnet masks are the same, and the IPs differ only in the last octet.
Any further suggestions are much appreciated.
Fre
nk
