Help with Reference from subVI to VI !!
hi people. i need to send values from a subVI to the mainVI. particularly, i have a boolean that changes according to X event, and I need to change an case structure according of its value.
i have read some stuff from the web but all of them aims to the use of references, but from the main to the subVI.
heeelpp
and thanks a lot ^^
(2,498 Views)
Go ahead and post what you've got. It is possible to:
  • grab a referance to the sub-vis panel -
  • return referances to its objects,
  • peek at the object labels to select just your desired control/indicator and
  • get a value from a property node from the controls referance BUT,......
 I'm guessing that there is an easier way to get what you want since your data structure seems a bit "inside out."  Not really a killer but, when you go to maintain the code you'll wish you had a cleaner solution.
(2,493 Views)
You should also look at the examples that ship with LabVIEW on how to use references. You can also take a look at this nugget: http://forums.ni.com/t5/LabVIEW/Nugget-Using-control-references/m-p/570756
(2,481 Views)
