Help with USB 6501 to signla a digital exposure controller
I am trying to use the NI USB 6501 to control the shutter from a Spectra-Physics Digital Exposure Controller. The shutter can be controlled using a coaxial cable with a BNC connector.  I dot not have much experience with digital outputs.  I have connected the "main pin" and ground but after that I could use some help.  I have also looked into the write digital channel vi.  Any help would be greatly appreciated.
Here is the link to the product....http://www.newport.com/Exposure-Control-Instruments-for-Large-Area-Illum/378091/1033/info.aspx
(2,455 Views)
Any reason you don't want to use RS232 which is apparently on the instrument?
(2,448 Views)
the manual says that a the BNC connecter (J4) controls the shutter.  I believe I have it working now tho.
(2,442 Views)
