Help with VI - ASCII to TDMS
I'm trying to convert an ASCII file I generated in Matlab. I want to convert this file to TDMS format but somehow the saved file is an empty TDMS file.
The program I use to normally open the TDMS files is as following. I have used this program before and seems to open files I generated using a DAQ.
(3,174 Views)
Accepted by topic author jquinno
Your channel name has a space at the end of it in your write, but not in your read.  This causes the invalid channel error.
(3,154 Views)
Spot on!! Thanks.
(3,119 Views)
