Help with arduino temperature control project.
Hi zero,
as LINX uses a serial communcication protocol you should handle all communication in a serial way:
Message 21 of 24
(552 Views)
I Want only the fan speed control based on temperature.Can you please provide me the code
Message 22 of 24
(416 Views)
Hi chan,
Why should I provide code?
Why don't you show some effort on your own?
How is fan speed related to temperature?
How is fan speed controlled? Is there a speed range, are there certain speed steps?
Which kind of control scheme do you want to implement?
Which DAQ hardware do you use?
Which software do you use?
The code basically consists of 3 parts:
  1. Read the current temperature.
  2. Apply your control algorithm to calculate the desired fan speed.
  3. Output the fan speed to your fan.
See how far you get…
Message 23 of 24
(414 Views)
basically I tried this with VISA software but it is not giving any output so here I decided to use ardunio software
Message 24 of 24
(408 Views)
