Help with block Diagram
Hi  , I am trying to control a servo with the MyRio 1900 and I am following a block diagram but I dont find a specific function call Smart open.vi does anyone know where is it or how can I find it or if it changed the name ? the block diagram reference is in 2018 version of LabView MyRio Toolboox and I am using the 2019.
(1,951 Views)
The Smart Open is part of the LabVIEW myRIO Module, You can download from myRIO Toolkit if you don't have this toolkit installed.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(1,900 Views)
The Express VIs within the myRIO Software Toolkit (if you are running LabVIEW 2019, you need to install the 2019 Version of the Toolkit) use Smart Open, which looks like this (called from within the myRIO Toolkit's SPI Express VI):
Bob Schor
(1,865 Views)
