Help with comparing negatives and positive values
Well guys I make this example to show you what i'm talking about
With this example I can get positives and negatives numbers in Numeric
But for me, the "minus" don't mean anything
Example:
If I have "100 -200" for me the greater value is -200
but if I compare bouth values I received 100 as greater value
I do the same calc for 3 differents variables like A, B, C
and after that I have to calc which value is the "greater"
But my problem is, If I have the values "-350 300 -400"
the greater will be "300" but for me the "minus" don't mean anything
so I need the greater value is "-400"
For all positive values, its works fine!
I compare A and B, after that the greater is compared with C and have a result!
but When I have negative values and positive values... I got that problem...
and When I have only negative values I have a problem too.
"-300 -400 -500" for me the greater value have to be "-500" but labview shows "-300"
because -300 is greater than -500 in algebriac.
And If I use absolute values I will always have a positive value... but I need to know if the value is negative or positive
Anyone, can help me with that?
Message 1 of 13
(5,992 Views)
I suggest you do your comparison with the absolute values of the numbers. That should return the result you want.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 13
(5,986 Views)
Accepted by topic author EduU
Ben
Message 3 of 13
(5,981 Views)
Yes, I already do it with absolute values
but If the "greater" value is the negative one.. I need to know that
so I have to find a way that it shows me if the number is positive or negative
I have "300 400 -500" with absolute values I will receive 500 as greater value
but the real greater value is -500 not 500
Message 4 of 13
(5,975 Views)
Ok all,
it returns just the magnitude not the nasty sign that is meaningless to the OP
Message Edited by Jeff Bohrer on 10-29-2009 11:30 AM
Message 5 of 13
(5,969 Views)
Please look at that sample code again.
The abs value is just used to decide which element had the largest magnitude. I then index out the original value as per your desire.
Ben
Message 6 of 13
(5,947 Views)
Well Jeff, this way still gives me only positive values
because x² make any negative number positive
I will try explain my point again
I have to get the greater number even the number is negative
and when i have that number i have to plot it with the signal
Like I have 5 numbers "100 144 -155 -200 -298"
The greater number is 298
so I have to plot it like: -298
If I use absolute values, ok i will find 298... but I will think it is a positive values
when it is a negative value
Now you guys understand me?
Message 7 of 13
(5,937 Views)
Ben's solution does that
Message Edited by Harold Timmis on 10-29-2009 12:43 PM
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 8 of 13
(5,930 Views)
Well the Ben explain is right..
sorry at the first time I saw I missunderstood it.
Really apreciate that... I thought for like 2 hours and don't figure out any way to do that
and you did it in 10 seconds haha
Message Edited by EduU on 10-29-2009 11:47 AM
Message 9 of 13
(5,925 Views)
10 seconds after 11 years of practice. Smiley Tongue
Ben
Message 10 of 13
(5,906 Views)
