Help with comparison
I'm new to LabVIEW and am currently trying to make a VI where is need to compare two things and if one item is true do something and if the item is false do another thing. In my case if the value 1 is greater than value 2 then i need to take the difference between them and display that number. If value 1 is less than value 2 then I need to light up a boolean LED.
Hopefully someone can help me out. I tried working with the case structures but couldn't get it to work.
Thanks!
(4,028 Views)
This is a very basic use of LabVIEW. Have you had a look over the introductory manterial online or in the help file?
Perhaps if you post your code we can give you some ideas as to how to proceed.
(4,020 Views)
Accepted by topic author steggets
Check this
Munna
(4,013 Views)
Sounds like you just did his homework for him.  😉
Bill
CLD
(Mid-Level minion.)
(3,967 Views)
Thanks! In the false case what is the NaN box?
(3,939 Views)
Hi steggets,
that's a numeric constant set to NaN…
(3,935 Views)
