Help with control
I have a numeric control ,  I set the minimum to 1 and maximum to 50, with increment of 1. However, I do not want the number 7 to be available in the numeric control. Is there a way to handle this using property node? or any other simpler way, I want to avoid many codes as possible.
i.e. the control values are 1 2 3 4 5 6 8 9 10 11.......50. If the user tried to type in 7, it will either change to 6 or 8, and if he uses the increment button from 6 it will jump to 8.
(3,528 Views)
Probably you would need to use a Value change property in an event structure.  Whenever the value changes, check if it is equal to 7.  And if it is, make the value either 6 or 8 (whichever you want) using a local variable or a Value property node.
(3,519 Views)
Hello...
See attached VI. It should solve your issue.
Dan07
(3,504 Views)
Hi;
I think this example can help you get what you're looking for.
Good luck
Francisco Arellano
Francisco Arellano
National Instruments Mexico
Field Systems Engineer - Energy Segment
www.ni.com/soporte
(3,476 Views)
This is as simple as I can get it.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,453 Views)
