Help with double click event
Hi guys
I'm using this event to select e cell in a table and write a user value inside it, all works correctly.
The problem is that when the write was happened a mouse selection starts from that cell and it stops until i click again.
I've tried all property node (selection size = 0, selection start = 0 etc....) but i can't solve this problem
look the photo
i write 333 value and a strange selection starts
can you help me?
thanks
http://www.sd-studio.it - web design agency
(2,770 Views)
Could you attach a small, easy example that would allow me to reproduce this? What version of LabVIEW do you use?
AlessioD
PS: Now you can post your questions in Italian by browsing to La Comunita' Italiana.
(2,730 Views)
