Help with downsampling a single wavefornm
Hello gents, i've found this old topic with a nice subVI that helps downsampling an array of waveforms
https://forums.ni.com/t5/Example-Programs/Down-Sample-Waveform-Data-Using-LabVIEW/ta-p/3508410?profi...
I tried to change it in a way so that my input and output would only be a single waveform (DBL) because i'm not working with array of waveforms and it complicates my life.
If i change the input with a single waveform then it gives me some error asking the Number of Iterations needed while this number is not asked when working with arrays.
Can anybody help me to fix this?
Thanks for your help.
(2,676 Views)
Accepted by topic author BonifacioLupo
Hi Bonifacio,
what about this simple function?
("Resample Waveforms (single shot)")
(2,661 Views)
