Help with quitting Excel with activex (save-dialog)
Accepted by topic author CarlesD.Ward
Hi CD,
As per my knowledge in LabVIEW and ActiveX,
instead of using those many nodes, I would recommend you to use simply the 'Save' property node of the workbook and then quitting the Excel using 'Quit' property node of excel application.
Hope it helps.
Message 11 of 12
(1,018 Views)
Hi everyone.
Thank you for your input. I finally got it working.
The final solution was:
- _Application.DisplayAlerts = false
- _Workbook.Save
- _Workbook.Saved = true
- _Application.Quit
Regards
CD
Message 12 of 12
(1,007 Views)
