Help with resolution output to an excel file with keithley 24xx
Hi there.
I am trying to write voltage data from a keithley 24xx to an excel spreadsheet  with very high resolution(.0001 volts/amps). I have my instrument driver setup and i can input the values i want into the instrument and can see them on the display but when i go to the excel spreadsheet, any value under a miliamp is written as zero.
I have tried to change the rounding on the actual spreadsheet, using "to extended precision float" as well as other conversions but the program still writes the voltage/amperage values as an array of zero's.
Has anyone ever encountered this problem before? It seems like there would be a simple solution out there but it hasn't hit me yet.
Any suggestions would be greatly appreciated.
(2,786 Views)
Hi proph,
maybe you should attach your VI or just show an picture of the block diagram?
- HOW do you write the data to a spreadsheet?
- Do you use RGT to write "real" Excel files or just WriteToSpreadsheetFile creating simple CSV files?
- When using WriteToSpreadsheetFile: did you set an appropriate format string? Default is "%.3f" which rounds to "milliamps". Try "%.6g" instead (or read the help for format strings)!
(2,784 Views)
If you are using the "Write to Spreadsheet" or "Array to Spreadsheet string" vi then use %S as the format string.
%S formats to your number to a string exactly as the number, no rounding or truncating will occur.
=== Engineer Ambiguously ===
(2,778 Views)
So My VI is bigger than just 1 page but here are 2  screenshotsof the writing process:
Im using write to spreadsheet file.The default value was indeed %.3f so  I'm going to try to change the format and see if it works =D
(2,761 Views)
Thanks guys!  both solutions resolved my problem =D
(2,753 Views)
