Help with rewriting this VI.
I had posted a VI here a few months ago asking for advise on how to clean it up. I have since been asked to see if anyone here would be interested in some side work rewriting it. The goal is to have 3 - 4 smaller VI's written instead of the 1 large VI. Example: 1 VI for just the alarms Tab, 1 for the JPS... Let me know if anyone is interested and the aprox cost for this.
Chris
(3,131 Views)
Hi Chris,
do you really expect someone will do your work on this huge (in terms of desktop real estate) vi??? Especially when all subvis are missing?
But you will get a lot of tips to clean up this piece of code:
- Use arrays for repeating tasks! In those clusters you 12 times a block of (site quality, LED site, fill color site). Make those in an array and set properties in for loops (using references to the actual indicators).
- Add all those number to array -> array to cluster operationss to the first point: you really should redesign your data structures...
- Cleanup in general (left-to-right wires...)
- Don't hide the laels of terminals. How should we know what's all those items?
- Put same tasks in subvis instead of copy&pasting it all over the block diagram...
I wish you luck on doing all this Smiley Wink
(3,122 Views)
I don't think the forums are the appropriate place for asking people to do work in exhange for money.
(3,113 Views)
OK this is the third attempt at composing a proper reply.
FIRST
Get in touch with your local NI rep and talk to them about who is local and can help you. If that fails, please e-mail me at
bar@DSAutomation.com
And I will forward your contact info to the right people. We do re-writes like that regularly and should be able to help you.
Ben
(3,090 Views)
Just for reference, this VI has been seen here a few months ago.)
(3,080 Views)
