????Help with serial communication.
First of all, debug the commands in hyperterminal. Once you have the syntax figured out, take the command string and use that as the top input of a concatanate string function. The second input of the concatanate string function should be a carriage return constant. The carriage return constant is on the string palette. From the documentation you attached, I don't think you should be including the "[" or "]" characters in the string but experimenting in hyperterminal should tell you all of that.
Message 11 of 12
(705 Views)
Hi,, I am playing with serial for serveral day. Could u pls help me. I send command to control servo moter with Hyperterminal, it works very well !!
After I check communication, I installed Labview 7 and use serial example to send the same command. But it doesn't work.
So I comeback to check with Hyperterminal again but the command that I sent doesn't work.
Do u have any Idea about this. I am very astronising about it.!!!
Thanks a lot
Message 12 of 12
(705 Views)
