Help with thermocouple channels
I'm currently trying to read Thermocouple data on 30 channels. The thirty channels are divided up on two cartridges(channels 200 and channels 300). However anytime it tries collecting data from the 300 channels(301-312) it turns off.
(2,484 Views)
You really made photos of your monitor? 🙂
You can make screenshots in Windows using print screen. But the best if you attach your actual VIs, otherwise we can have zero idea what is wrong with your code...
(2,475 Views)
