Help write DIO
Hi there,
I think my last message is lost !
So I want to operate with 5 or more DIO channels sepperatly,
it means, to set each channel for his own.
But when I wrtie to single DIO line and a few minutes later i write to
the next channel, the programm reset my first channel to low, why and
how can I fix this problem ??
tnx for help
zassi
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,149 Views)
Hi Zassi,
You are writing in the same address, but diferent channels.
This way, you should create one it chews,
for it is not altered what you wrote before.
Have a good work and success.
Roby
zaske@my-deja.com wrote:
>Hi there,>I think my last message is lost !>>So I want to operate with 5
or more DIO channels sepperatly,>it means, to set each channel for his own.>But
when I wrtie to single DIO line and a few minutes later i write to>the next
channel, the programm reset my first channel to low, why and>how can I fix
this problem ??>>tnx for help> zassi>>>Sent via Deja.com
http://www.deja.com/>Before you buy.
(3,149 Views)
