Help!!
Hello Ppl
I am new lAbview programmer. I am trying to create a
subVI which I am going to use in another VI. When I try to instantiate
the sub vi in the main VI, the terminals of the subvi don't show up.
How to get around this problem? Can Anyone help...
Bye
Sudarshan
(2,705 Views)
You have to define the connections of the terminal panel yourself. On the subVI, right click on the icon and select Show Connector. You'll see a terminal pattern that LabVIEW selects for you. If the pattern is not to your liking, right click on the terminal pattern and choose Patterns to select a different one. Once you've decided on a terminal pattern, move the mouse over the terminal pattern. It will change to the wire spool icon. Click first on one of the terminals and then on your control/indicator. There is also in the LabVIEW help, a section titled Assigning Terminals to Controls and Indicators tha tyou should also refer to.
(2,705 Views)
