Hesitate to pass data between vi's
How to pass words / phrases to other vi's, so they appear as constants?
Hugo Santos
Hugo Santos
Student at ISEC - Master Mechanical Equipment and Systems
Message 1 of 14
(3,314 Views)
have you used the search box at the top of the NI homepage?  look up sub vi basics
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
Message 2 of 14
(3,308 Views)
you can use the FGV-Structure:
Using a Functional Global Variable to Communicate with a SubVI
https://forums.ni.com/t5/Example-Code/Using-a-Functional-Global-Variable-to-Communicate-with-a-SubVI...
You can also create a gloabal variable in LabVIEW:
https://www.ni.com/docs/en-US/bundle/labview/page/creating-global-variables.html
But I think FGV is the better way.
_____________________________________________________________________
---Please mark a post as a Solution if it solved your problem ---
Message 3 of 14
(3,304 Views)
You could also concider using an Action Engine as I described in this Nugget.
Ben
Sorry Xenox but why stop at FGV when you can do an AE?
Spoiler
reminds me of a campaign line that developed in my head (bad head!) while watching a recent political debate "Why settle for mediocracy when you can choose the vest?"
This posting was not endorsed by any candidate or even myself!
Message 4 of 14
(3,280 Views)
Thanks for the reply, resolves some of the obstacles.
But for the string does not work.
There is another way for the strings?
Regards
Hugo Santos
Message 5 of 14
(3,268 Views)
Regards
Please post an image of your code and show us where you want to do the transfer of the string.
Images should let us help you better than us just gueessing at what you could be having difficulty coding.
Ben
Message 6 of 14
(3,264 Views)
Below is the example code only works with numbers, and also liked to work with words.
Greetings.
Hugo Santos
Message 7 of 14
(3,258 Views)
Just edit the FGV and right click the control and indiactor and choose "Replace" then navigate to a string control/indicator.
Save done.
Ben
Message 8 of 14
(3,252 Views)
Thanks for reply.
I've tried to do what you said but does not work, when I do replace, is not accepted.
Greetings.
Hugo Santos
Message 9 of 14
(3,249 Views)
What you are attempting is trivial.
Show us a screen shot of your machine when you are attempting the replace and please report any errors or messsage you see.
Ben
Message 10 of 14
(3,243 Views)
