Hex String display
I getting a string from CAN Controller as 002A0100   005A0004 total 8 byte i have to display  first 4 bytes in little indian format without spaces followed by space with following 4 bytes also in little endian format and for next string  should go to next line.
E.g :    00012A00           04005A00
            Next msg
Message 1 of 9
(4,915 Views)
This appears to be the same question you asked here.
Message 2 of 9
(4,907 Views)
In this case the string in Hex string not a normal string.
Message 3 of 9
(4,902 Views)
I do not understand what that statement means. What is a "normal" string?
Message 4 of 9
(4,898 Views)
I getting a Hex string from CAN Controller as 002A 0100   005A 0004 total 8 byte i have to display  first 4 bytes in little indian format ( 00012A00 )without spaces followed by space with following 4 bytes (04005A00) also in little endian format and for next string  should go to next line.
For E.g
 Display should look like  00012A00     00012A00    what i can see in my output is 0001 2A00  0001 2A00 ( 1st problem) and 2nd i am not able to add next string in next line if i try to add the string using EOL string it is taking its hex value.
Message 5 of 9
(4,896 Views)
Hi srinivas,
try the attachment. It's a straight forward solution 🙂
Message 6 of 9
(4,861 Views)
Accepted by topic author srinivas
Thanks it works exactly what i wanted.
Message 7 of 9
(4,852 Views)
Then mark Gerd's reply as the solution and not your own message.  You can unmark yours from the option menu to the upper right of your message.
Message 8 of 9
(4,845 Views)
:smileyvery-happy:
Cory K
Message 9 of 9
(4,828 Views)
