Hex String to 'Ascii Hex' String!
I am having a mental block and wonder if someone can help!!
I am reading a serial device and getting a hex string back. I need to display this hex string to the operator within a pop-up box (PDA). The Message box will obviously contain normal text with the HEX code appended to the bottom.
When I run the code the pop-up box displays the legible message to the user but the HEX string returned appears in the appropriatte ascii characters (because the pop-up displays normal string).
My question is, how to make an hex string appear within a normal display string indicator 'the same' as it appears in its Hex display indicator:
0x0A1C - Hex display needs to appear as 0A1C in normal display string indicator.
Thanks in advance
ssk
(5,937 Views)
Accepted by topic author ssk
See picture.
Message Edited by andre.buurman@carya on 04-08-2009 12:41 PM
André (CLA, CLED)
(5,932 Views)
Hi André,
Thanks for your prompt response!
ssk
(5,927 Views)
