Hex String to Cluster Conversion
sorry I didn't see your last answer. see the attached VI, hope it's what you need
J.D.
French Labview beginner
N'oubliez pas de complimenter les bonnes réponses - Don't forget Kudos for good answers
Message 11 of 20
(2,982 Views)
OK, so maybe we don't really understand what you nee ! 🙂
If you need to extract each character of the hexadecimal string, see attached below...
Message 12 of 20
(2,979 Views)
Thanks for the Reply.
-mfp
Message 13 of 20
(2,978 Views)
One more Question.
Please see the attachment.
How shall i remove that wire error?
-mfp.
Message 14 of 20
(2,958 Views)
Hi Favas,
"How shall i remove that wire error?"
By using IndexArray you could index the first array element... (Did you read the error message: you try to wire an array source to a scalar sink!)
Message 15 of 20
(2,954 Views)
You should use the index array function (in array palette)
look at the linked exemple
J.D.
Message 16 of 20
(2,941 Views)
when i use index array to get an element, getting a wrong value.
but when i put an indicator at the substring, getting the correct one.
i need the value in hex format itself to fill into the cluster.
what shall i do for that?
-mfp.
Message 17 of 20
(2,930 Views)
Hi Favas,
sorry, my fault. (Partly yours, as attaching a VI could have helped...)
You take a string subset of two chars. Those two chars form one hex value. To get that value you have to use "Hexadecimal String To Number" instead of "String to U8 array"...
Message 18 of 20
(2,924 Views)
okay.
thanks for the support.Smiley Happy
-mfp
Message 19 of 20
(2,913 Views)
This is a ridiculously long and winding thread with tons of guesses and ambiguities, as well as weird rube goldberg replies, one marked as "solution" before the discussion even gravitated to a consensus.
Can we start from scratch! Don't post code images! Only post actual VIs.
Make a simplified version containing the desired data in controls (the data you have) and indicators (the results you want), make the current values defaults, save, and attach the VI.
Thanks! 😄
Message 20 of 20
(2,899 Views)
