Hex String to Float
I'm reading data from an instrument that
sends the data in Hex (ASCII String)
and I need to convert the data to Float.
All labview Vi:s converts to integers and spoils all my attempts.
Anyone have an idea?
Example (Motorola format)
"3F7851EC" convert to 0.97
Pelle
Message 1 of 12
(16,376 Views)
> Pelle
You need to find the algorithm that motorola uses.
Hex numbers are integers only (by a straight conversion).
I don't recognize this format but the intger equivalent is something
over 1 X 10 ^9.
This has noting to do with LabVIEW it is a number format problem.
Kevin Kent
Message 2 of 12
(16,374 Views)
"Pelle Soderberg" schrieb im Newsbeitrag
news:3a54f8aa@newsgroups.ni.com...
I think there is no possibility to convert it directly only with Labview.
But you should be able to call a C function (see Code Interface Node)
C-function to convert a hex-ASCII float value to numeric float
float strg2float( char *stringval)
union {
unsigned long ulong;
float floatval;
}conv;
sscanf( stringval, "%X", &conv.ulong);
return( conv.floatval);
Greetings Mik
e
Message 3 of 12
(16,374 Views)
Colleagues,
Conversion is straigtforward and very simple.
Connect your string "3F7851EC" to "Hexadecimal String To Number"
function, leave the all inputs, except string, unwired.
You'll get U32 number. Then use "TypeCast" to convert this number to
"SGL" LabVIEW type. You'll get your 0,97 in a single float numeric
indicator.
This is all described in IEEE floating point numbers format standard,
and LabVIEW strictly follows it making the all conversions for you.
If you need more explanation, let me know.
Sergey Krasnishov
____________________________________
Automated Control Systems
National Instruments Alliance Member
Moscow, Russia
sergey_acs@levsha.ru
http://acs.levsha.ru
Michael Ziegler wrote:
> "Pelle Soderberg"
erg@flir.com> schrieb im Newsbeitrag
> union {
> float floatval;
> }conv;
> Greetings Mike
Message 6 of 12
(16,374 Views)
"Pelle Soderberg" wrote in message news:3a54f8aa@newsgroups.ni.com...
> Pelle
The VI below seems to do the trick although I would be the first to admit that it's not very elegant
Regards
Keith Fuller
Message 4 of 12
(16,374 Views)
"Keith Fuller" wrote in message
news:3a5b0042@newsgroups.ni.com...
> Pelle
Sorry I forgot to show that the numeric constant 0 attached to the "From
Hexadecimal" must be U8 representation
Regards
Keith Fuller
Message 5 of 12
(16,374 Views)
"Keith Fuller" schrieb im Newsbeitrag news:3a5b0042@newsgroups.ni.com...
Ok, the Type Cast does it, but so its more elegant:
Mike
Message 7 of 12
(16,375 Views)
Thanks Mike
that did the trick
Pelle
"Michael Ziegler" wrote:
>This is a multi-part message in MIME format.>>------=_NextPart_000_000E_01C07A54.17E37CC0>Content-Type:
multipart/alternative;> boundary="----=_NextPart_001_000F_01C07A54.17E37CC0">>>------=_NextPart_001_000F_01C07A54.17E37CC0>Content-Type:
text/plain;> charset="iso-8859-1">Content-Transfer-Encoding: quoted-printable>>
"Keith Fuller" schrieb im =>Newsbeitrag
news:3a5b0042@newsgroups.ni.com...>> The VI below seems to do the trick
although I would be the first to =>admit that it's not very elegant>>Ok,
the Type Cast does it, but so its more elegant:>>>>Mike>>>------=_NextPart_001_000F_01C07A54.17E37CC0>Content-Type:
text/html;> charset="iso-8859-1">Content-Transfer-Encoding: quoted-printable>>
HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">>>content=3D"text/html; =>charset=3Diso-8859-1">>name=3DGENERATOR>>>>>
dir=3Dltr=20>style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT:
5px; =>BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">> >
size=3D2>The VI below seems to do the trick =>although I=20> would be the
first to admit that it's not very=20>elegant
face=3DArial size=3D2>
Ok,
the Type Cast does it, but so its =>more=20>elegant:
3D""src=3D"cid:000901c07a4b$b61773a0$4f2116ac@kayserthrede.de"
=>align=3Dbaseline=20>border=3D0>
face=3DArial=20>size=3D2>Mike
>>------=_NextPart_001_000F_01C07A54.17E37CC0-->>------=_NextPart_000_000E_01C07A54.17E37CC0>Content-Type:
image/jpeg;> name="ClipBoard.jpg">Content-Transfer-Encoding: base64>Content-ID:
<000901c07a4b$b61773a0$4f2116ac@kayserthrede.de>>>/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEB>AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/2wBDAQEBAQEBAQEBAQEBAQEBAQEBAQEB>AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/wAARCACAARQDASIA>AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQA>AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3>ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm>p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEA>AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSEx>BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElK>U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3>uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD+/iii>igAooooAKKKKACiiigAoor8gf+Cw3xM8OfCjwB+yv4u+Ivij9oDQPgloH7QHx28f/HrR/wBmj4z/>ABT+BHxT8ffCz4Ef8EwP+CiP7SF34K0nxv8AB/4ofBrxbP5/i34NeEfEVh4cn+Ivhzw5rniPw5oM>HiK9j0yOaSMA/X6ivxh8AfA3/gnx4n1H4EfDnxD+2H8YLP8AaD+Pnwf8LfGHwL8GfAH/AAXr/wCC>jXxD1H4h+Fde8K6p4nvPGXwIe+/a/wDA/jb42fB8W3hrxjf+Fvixo/w10LTvFXhXwtqniiXRNBjs>9U07S+fs/Dn/AAR71H/hHP7P/wCCk/xAv/8AhMfh/wCNfix4R+x/8F+P25rr/hKvhZ8Nf+E//wCF>i/Evw55H7fr/ANufD/wD/wAKo+KX/Ca+MtM+1eHPCv8AwrXx/wD27qVh/wAId4i/s4A/b6ivyB1v>4Cf8EzvDP/Ci/wDhI/23P2gPD/8Aw1B/ZH/DNH9t/wDBcb/goRpX/DRH/CQf8It/YP8Awov7f+3Z>b/8AC2/7b/4TjwV/ZH/CAf8ACQf2l/wmHhb7H53/AAkGk/az9nX9mr9iL9qDw58R/EXwt+Ln7f8A>d/8ACpP2gPj5+zR8RdCvP+CuH/BSu48R+D/in+zv8U/E3wt8XaT4k0zw7+3N4g/4R/8A4SD/AIR/>T/iL4KsNdn03xHqvws8ceAPF2p6Don/CTQafCAfr9RX4Q32n/wDBKWz8VfBDR4v2zf2n9T8E/tC/>B/8Aam+Nfww+O2lf8FvP29734Ba94V/Y41H4c2vx20+1+J6/8FAV0jVPEHhPSPHuseMdQtfD0Wt6>doPgv4QfGvxD4x1XwvbfD+6W86CP4c/8EztI0fxv418eft0/EDwl8MtE/sfxH4T8fx/8HAn/AAUI>vdH1f4Wax4E/Zv8AEdt4/wDG97rP7ZHhbw/4D+1+IP2nvhJZaPZ6b4j8d+HNX8CfGD9m/wAfx+Nb>e9/aA8M+CtIAP2+or8gfH/wE/wCCZ3wo+Kfgr4F/FL9tz9oD4a/G34lf8I5/wrr4O+P/APguN/wU>I8HfFPx9/wAJj4jvfB/hH/hCvh74i/bs07xb4q/4Srxbp2oeFvDn9haRf/254jsL3RNM+1anaz2q>fT//AATJ8WeKvHv/AATb/wCCfPjrx14m8QeNPG3jT9iD9lDxZ4x8Y+LNZ1HxH4q8WeKvEfwG8A6x>4h8TeJvEOsXN5q+veINd1e8vNU1nWdUvLrUdU1G6ub6+uZ7meWVgD7fooooAKKKKACiiigAooooA>KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK/CH/gvvpvhXxH+z9+zr4F8Y/Fv4>P/AnSPit8YP2sfgpZ/Fr4/ePdO+GHwa8F+Kvjf8A8EdP+CpHwj8C6h8QvHmqRz23hzw/deNvGnh7>S5rqKz1HUZ57+Cx0fStW1e6sdNuv3er8Pf8Agvt/yZ38Nv8As5bwd/6q74yV9/4WcDf8RL8QuE+A>/wC1P7F/1ozWnln9q/Uv7S+o+0pVant/qP1vAfWbez5fZfXMPfmv7RWs/wBQ8FvDb/iMHipwP4Z/>21/q7/rlndLJv7b/ALO/tb+zfa0a1X6z/Zv17LPrnL7Ll9j9fwt+a/tVaz+Y/iX+0r+xf4m+Mvxh>0Pw9/wAFMv8AglBJ+z5+0b+2/wDsaft4eOvifrP/AAUD+FOmfGX4X+Kv2PIP2Kms/gr4T+BNjp+t>eCfil4f+JVz+wl4Ohufi5rH7Rnwo1HwPB8bfE1xF8JfGUnwe0u1+MPgHwx8RfsX+C/hT8FfAuqf8>FWv+CUFxq/w4/Zg/4N6fgprlxp/7dHwpl0668Vf8Emf20PGn7Rn7RmoaVNcT2tzP4f8AGngnxHY6>X8FLq8s7HUfEfiqK6sfHWlfDjSEh1yf0L4a/A/8AYl8NRfBez+PP7BPxAtvhbrP7J/wT+KnjL9qe>D4gftP6ha+KfiT8RvBnhCTTrbwj4M8DWV38LPF3/AAsj4p+JtN+Afw6+B/w4+Mmq/t7ePf2jvEvh>3w98O/8Agn9rH7PGu6F+0fd+oL+z/wD8E+7X4NfEe+8Uf8E+/EHgH9tDw54g8QeDfhx+wB4w/aZ+>JM/xl+KPjTxhP8TtW/ZK0TTvGfgP4ieO/h3P4f8A2h/h38Or/wAdeMfjD8OdU+K/wC/Zug8F/tM2>fxK+LF1p37HP7RniDwT9Lm3C3gxk+a5nlGK8RfE+picqzDGZbiJ0PB7hSVCdfA4mphas6MqnjjSq>SpSqUpOnKdKnNwacqcJNxX1+ecF/R8yDOs3yLGeK/jJVxeS5pmGU4qphvAPgmeGqYnLcXWwdeeHn>V+khRqzoTq0ZSpSqUaVSVNxc6dOTcV8G/tP6p8Cfib+z/wDH34F+EP8Agq//AMEwPGnh/wCN/wDw>8Ui8IeFp/wDgtJ4x/Y58CfArxH+2F+1/+2F8dNI+K3i7RP2cdI8Y2X7bv/CY/DL9oT4M+FviL+z/>APtFaRpXws+Fusfs/eItE+HOteN/D/7Q/wAStXh/V/4Ufthf8E2/BH7PH7TX7O3iH/gpf/wSg8W6>R8UvjB+21428C6n4/wD2lPgN8VPh74m8K/tmfFv4oftDXmh/Hf4FX3xV8DW2u+H/AAV42+OnjH4R>eKfhto/xTvdO+MPwz8C6X4zl8c/DfV/inqnw6+F/oX/BM3xx+z18BLH9sn4IS/Ef4afDj/hDP24f>2nZPCPgDxT8RtF0/xHYfCv4feHPCsI1uOy8Va83ibUPDPhrwz4M1q41TxTfveQwWPhrW9R1bVG/s>3U7mL9UfB/xo+DvxDvtO0vwB8WPhp451PV/DN3400nTvB/jvwt4mvtU8Haf4juvB9/4s0600XVb2>4vfDNl4tsr3wtd69bRy6XbeI7S60Sa6TU7eW1T5/j/w6zXgriLOMqw9DOs1yfLvqlbC8QYnh/E5V>SxuBx2Bhj8NiqtCGJzTC4Xmpe3jKNPNMZR5sLiHTxNSNKbj8v4n+FGdeHnFefZLhcNxDneQZV9Rx>GC4oxfC+LySjmGW5jltPM8Jja2Gp4zOcFguaj9ZhOFLOcwoKeCxTp4urCjUlH+U34ieKv2WPiT8E>/iVaXv8AwVB/4JAaR8YPi3+yB/wUx/ZA1XSNT/4KG/Drx9daH4c/bL+EX7OvhD4KeOvil+1zqHhn>w18Tf2wfiB8H739jj4N/B/UPHvxQ+Avw7+Keq/s4+L9Ch8ffEn43fGD9mG68e/tffT/gf4wf8E29>L/4KceNP23fG3/BSX/glB4l8Ev4g/aY8WfCy3uf2xPgNrPxM8BeKvjZ+y3/wSM/Zz0XxNo0OranH>pHhbxBHpH7EP7TnhrxNrPh3xYdRX4e/FTwno1pc6tbeOPiDofhP+l6ivzs/KD+EP4cftxfsnfs06>P8E/+CcHhP8AbZ/YA+Nep6x+0B/wRe+Mfx7+L2mftFfEnwJ4E+F2sfsL+BP+CZnhT4z6V8Lfip4n>/Zuk/Y4+Nfw/tfhv+wfc/FDT/HHib9sn4G+O9R1jx3rvwN0b4Lax8bfAvhzwZ8Vv6vf+CTv/ACiy>/wCCaf8A2YB+xv8A+s6/Dmvv+igAooooAK+IP+Chvjn4meAv2brC8+EXxJ8QfCDxt40/af8A2D/g>pH8SfCeh/D3xH4q8J+Ff2hf26f2cvgP8RNQ8M6T8V/BPxH+HcviCX4d/EfxVY6NdeKvAvijTtL1G>6ttUGlT3Nlblft+vgD/gpZ/ybr8Of+z/AP8A4JO/+vTf2N6APgDwB8TPG/i74WeNf2hPFf8AwUO/>4K//AAe/Zl8P/s/+I/2sPA/7SHj/AOAH/BI/xB8LPjL+zP4U8OWfjfVfi74Kj+C37BXxb+IHgf7R>8P8AW/C3jzw58JP2h/AnwQ/aE8a+HPEF6vgv4QeINa+HPxj0f4bmteLP2lPh38LP2gPi38ff2mf+>C337O/h/9n/9n/4rftIX1t4/+Ev/AAQk8d/8LE8CfBTw5L4m+Imj+CvFn7On7Mvxx+GXh34gWFlL>o0fhzwR8avHvwj1j4if2xeal8OI/Fvh/4ffF3Wfh2ah+xl+0d8TvhZ+2D+zt8Kfgl8QP2N/hl8X/>ANgD9rj9mTXvht8a/wBq26+Pn7LGvftHfFXw54U8Dfs0eIf2JND0n4mfGrxB+zz+yB8C/D6ftAaD>qPhjRf2ff2I7rUPh18S/gVZxfso6ve/D6w8E/ATn/wBqD4I/ttftVaj+2l4h8Cfsv/tP/BPwT+0D>/wAEoP8AgoR+zxN8Jfj3+2x4H8Yad4//AGuPHHhX9nTwn+zaPDn7M/gj9qD43/snfAnw/deDtO+K>Oj+GPi54C8Y+Gtb8TeKtY+M8vx68L/Dm2Pw/8d/G8A+v/FnhP9pH9mv9pH9gWzvP2+v2n/j94J+P>37T/AI/+CnxJ+G3xr8AfsLWPhXUvCth+wt+2Z8eNJ1DT9W+A/wCxn8DviJpPiDSfiJ8DvAt9a3Vj>46j06406PVdL1TStRttRIh/V+vyB+Kvxk+Ivxb/aK/4Jjf8ACf8A7J37QH7L/wDwj/7f/iv+yf8A>heniP9ljxB/wnH9q/wDBLL/gqH9v/wCEW/4Zo/aW/aI+yf8ACM/2bZf23/wmv/CH/aP+Eg0j/hG/>+Eg8nXv7E/X6gAooooAKKKKACiiigAooooAKKKKAPP8A4s/FLwJ8DvhZ8S/jX8Utd/4Rf4ZfB/4f>+Mvil8RfE39maxrf/CO+BPh/4c1LxZ4u13+xvDun6v4g1f8Asjw/pGoah/ZmhaVqesX/ANn+y6Zp>97eywW0vyB/w8s/Z1/6Jz+3/AP8Aip3/AIKm/wD0G9H/AAVi/wCUWX/BSz/swD9sj/1nX4jV4B8K>IfHfwr/bJ02L9pe7/a/8PfE34z/tAftHeE/hT8YLP49aP41/YT/aK8CahY/HH40fs/8A7M3hv9mK>X4weL5vgj8QPhJ+yL4B0HXvGvxa0n9kP9mjWPEfxi/Zd8f2V/wDtNfFSy+M2tQftTAHv/wDw8s/Z>1/6Jz+3/AP8Aip3/AIKm/wD0G9H/AA8s/Z1/6Jz+3/8A+Knf+Cpv/wBBvX5wfs4/8FJfj749/Zu/>ZGtv2jPhD4f8V+JNf/Zg/wCCI/x3+K3xd+Hv7TXjT4deKvFnxM/4KPft06X+zt8KtUt/Bnw8+APw>40iLw/FpHw41z4+/H7wBb+LNI+HuqajrE37IcPhb4mfBvxJ4k+KbewfD7/gr7478QfCL9nf4nfEP>9kD/AIVjqf7av7P/AMHvjH+yH4Lb9oDR/Gd14g1j4q/Gz9jX9mOLSv2hNc0H4Zx6Z8FPh/dfG39v>D4B+IPAnjj4fL+0L478Qfs4t48+I/wAQvgt8IPjb4Xsv2YPEAB9//B39uj9n/wCOPxTtfgp4Rg/a>A8L/ABN1H4f+MPilo/hn46fsd/tf/syf8JF4E+H/AIj+H3hPxvrvhbWf2kPgX8KfD/in/hFvEHxW>+HWn63pnh3VdT1iw/wCEu0i6n09bKWS5i+v6/EH4H/tC/FP44/8ABVfwX4R+Nfwk+H/wf+Jv7M/7>P/8AwUc+BfibR/hb8ZvEfx18CeIv7bj/AOCDH7SGjeKdC8b+LPgh+z54gj8zw/8AtB6V4d1PRNQ+>HVv9g1jw5qE9rq+qWV7bSRft9QAUUUUAFfh7/wAF9v8Akzv4bf8AZy3g7/1V3xkr9wq4fx/8Mfhr>8V9GtvDvxS+Hvgf4leH7LU4das9C8f8AhPQPGOjWms21re2Nvq1tpniLT9RsoNTgstR1Czhv4oEu>orW/vbdJVhup0k/R/CLjfC+G/iXwdx1jsDiMywnDOcU8yr4DC1KdHEYqEKVam6VKpWvShNuomnNW>smfrXgR4jYLwj8X+APEnMctxWb4Hg7PqOcYnLcFVo0MXjKdKjXpOjQq170ac26qalU92yZ/P/NrN>n4s/Zl/Zy8Z/DT/goF+y54W+O3wo+Dn7PWifBL4c+M/jB8GPhNB8BNOT4HaB4O+NepaT4q+IfgP9>sDwt4b/ay8XavqfibwxrHx5+Jf7I3xog8G/s1DxX+yX8G/g98A/F/wAcvj9+1X429jn17Qtd8CeL>vjp42/4KHfsU6v8A8FJ/C/8AwsVP2efiF4M+P1n8P/2TvCfhzQdY8RWvwp+DV98HdQ8afELxBon7>P/7SPh/TvA3in9unwlrmr/Gb4p6z8SdTi1v4bfG6XWP2T/2C/GH7Ov6f/wDDF/7Hf/Rp/wCzT/4Y>n4Xf/MtR/wAMX/sd/wDRp/7NP/hifhd/8y1e/nWZeCuc5xm2cVaXijRq5tmWPzKpRpvhOUKM8diq>uKnShKXvShTlVcIuWrSTep9RxBm/0d+IM+zvPq1Hxow9bO83zLN6uHpS4HnToVMyxtbG1KNOU/el>ClKtKEJS95xjFy1bPgv/AIJ8fDH4CfHTRv26fEXin4e/CH4xeH/E3/BRn4+a1pOu+IPCfgz4haN4>h0bTLXRr7wPq2nanqOn6vZatpmn2Xj3xZeeFL+2nuLW0tfGfiG40iWOHxFqT3n0J4F8MeDvBH/BS>b4tab4P0Pwz4P/4Tb9kP4efELxTpXhqHS/Df/CY+Mb349fGGDW/Hmv6BpfjrQv8AhK/E032m1ttV>8a6j8JvH2qWf26Cyu/id8Nf7bj8NfFz7O8AfDH4a/CjRrnw78Lfh74H+Gvh+91ObWrzQvAHhPQPB>2jXes3NrZWNxq1zpnh3T9Osp9TnstO0+zmv5YHupbWwsrd5WhtYEj+VtKvvL/wCCk3jvTf7Q8v7X>+w98J77+yv7Y8j7b/Z/x6+NEH9of2B/wsTTP7T/sz+0/s39sf8Km8a/2H/a32L/hYnwv/wCEh/4R>r4ve7juO6/GmeeLOZYLE51QyDG8C1/qGU5lj51/YUMHi+DsBT9tQo1HglVlHLsPOXsaagvZ0Yx0p>Q5fpsx8SsT4h8R+OObZdjOIcNwxmHhpif7MyLN8zqYn6rh8BjuAMrpe3w1Cq8vVecMpw05/V6Spr>2VCMdKFPl+4aKKK/nw/lcKKKKACiiigAr4I/4Ke+C/B3xD/Ya+N/g/x/4T8M+OfCWr/8K0/tbwt4>w0HS/E3hzVP7P+L/AIA1Sw/tHRNatb3TL37FqdlZajafabWX7NfWlrdw7Li3ikT73r4t/wCChv8A>yZ78X/8AuQP/AFaPgmvzDxtr18L4MeLuKwtarhsThvDDj6vh8RQqTo16Fejwpm1SlWo1aco1KVWl>UjGdOpCUZwnGMoyUkmfo3g7Ro4nxc8LMPiKNLEYfEeI3BFGvQrU4VaNajV4myunVo1qVRShUpVIS>lCpTnGUJwk4yTTaPwh8G/wDBL7/gjh40+MuifDC2/Y28Z6P4J8cfGD4w/s6/Cb9ovWfg/wDsUj4N>fF39of8AZ+g+LE3xn+DPhPQ9I0DV/wBoPw74g8Byfs+ftEWtz4v+KvwJ+HPwk8RT/BPxM3gv4jeJ>bbxh8Hrj4mHjL/gl9/wRw8F/GXW/hhc/sbeM9Y8E+B/jB8Hv2dfiz+0Xo3wf/YpPwa+EX7Q/7QMH>wnm+DHwZ8WaHq+gaR+0H4i8QePJP2g/2d7W28X/Cr4E/Eb4SeHZ/jZ4Zbxp8RvDVt4P+MNx8M/vL>wp8Gvjt8NfHfwg0Hxt8EfiBp3wy/Y6/b/wD+CjP/AAUU8V/tAeH38HfEjwJ8WfhZ+03o/wDwUc1r>wZ8K/gV8KfhX4t8cftdeM/2gNAh/bl8DWHiXwPrn7NHhHw5qmsfC/wCLek/Dbxv8Qb1vhDF8XTxX>8Dv2mPHPjv4v+EYf2bfiB4e8P/tb/t//APBOb/goQvxS8QeOP2ez4E/Z88HfstaP/wAE49T+J3wH>+Oun+H/jZr/xNu/2gHvf2F/iF4d8NJ8Afh18ePgTq2sfEb4ST3Hx10/w/efEfXfhpl/xBPwx/wCi>Z/8AMzxB/wDPU1/4jB4i/wDRRf8AmIyLy/6lnkj0f/gmF+w1+xP8PPgh8EPjn4A/Y9/Za8DfG3SP>+Fl/2T8YvB/7Pvwm8M/FPS/7Q8XeP/B9/wD2d8QdF8I2Xi2y+2+Er298LXf2bV4vtPhy7utEm36Z>cS2r/rvXxb/wTy/5M9+EH/c//wDq0fG1faVa+CVevivBjwixWKrVcTicT4YcA18RiK9SdavXr1uF>MpqVa1arUlKpVq1akpTqVJylOc5SlKTk2zLxhoUcN4ueKeGw1Glh8Ph/EbjehQoUKcKVGhRpcTZp>TpUaNKmowp0qcIxhTpwjGEIRUYpJJBRRRX6efnIUUUUAFFFFABRRRQAUUUUAfE//AAUr8J6j49/4>Jy/t/eBdHmsrbVvGn7E/7VPhPS7jUpJ4dOt9R8R/Arx5o9jNfzWtteXMVlFc3kUl1Jb2l1OkCyND>bTyBYm/n6+H/AO19+1dafEyy/aY+H/8AwQj8davq3iK9174m+DDZftz/ALbXi34BaH4q+KmnapN4>t+NXwZ+A95+wtq/7N3w3+JvxS07xl43vvF/xt+E3w38M/EL4gp8Wvi/qXiDxhrUnxp+KFx4w/pH/>AG0P+TO/2sf+zafjt/6q7xVX58/sJfBP9nrxz8DPFvj/AOMHwM+GnxR1Pwx4Z/Zoj/tbxL8G9F+K>3jGLw5ov/BOr9jfWv7E0Cw/4RbxN4t1fZcXep3OleFvDtlf32oapqE8OkaXdanqPlXH9B+G/DPh/>V8O+IuMOMcjzXO8Tl3EGHy3CUcsxWKjVlSrf2Lh4YenhMPmOVxqVa2JzhVfbzxNSUY4dUKeHnKv7>Sl/VHhHwf4W1vCjivj3j/hvO+IsXlXFGFynA0MnxmMhWnQrvh3CU8JRwGFzXJo1q9fF5/wC2+sTx>lScIYVYalhKksR7Wj+WOj/Hj9p3w/ayafo3/AAbz+LdP0z/jG+Cx0mD9r/8AbT/sfw/o/wCx/wDt>HeN/2sP2X/CPhHR3/YJfTPBnw/8AgZ8bfiF4m1X4dfDrwna6L4E8P+BP+Ed+Clt4d/4Ul4K8F/Dv>w/5/8XfjN+3h4k+BPw7+E3wc/wCCDOmfD/xB8B/2f7H9mL9m/wATfEv46ft7fFbw58G/hFF4x/Z0>8WSWmm6N4I/Zh+A/xNvPiB4evf2Wvgt4j+E/xs0r43eF/jZ8G/in8PPBvxV8D/EKz8QaZrFt4k+m>tU+OHwK8XfBP4feMvD/7O/7Bfgvx34Q/4KM+Cv2efik4+F37POk+BPGfwT1PT/GWu6f4n8VXz6P8>f7L4PeB/G1lpEmlan4+8H+Mvinp9lJ4G8XeKPAXjrxDpSS6ZbfZ3w/8AiB+x38RNd/ZV0P8A4d3/>ALNPwp/4aS+GkfxK/tj9oDwT8LvhVoS/8XF0L4d/8ID8GdQ/4U/4l/4Xn8S9Y/tX/hOvBvhXyfh1>/wAJP8OtZ+Hnif7fpn/CdfYdB/bM98F+DchwrxeJ8Lc9xNOGNznA4iOF4ipRqYaeS5fjM4q1qsMd>xtgvaYfG5LgcTm2AqYV4h1cLCNKvDDY+tRwdT+iOJPo9+H/DGDeNxfgvxLi6VPMc/wAtxcMFxXRh>WwdTh7Ksbn9avWhmPiLl/tcLmPD2W43PMrq4J4qVbBU4UMTTwmZV6GAqfkv/AMEuvE/7U37OX7X/>AMKviB+2z+yf8YvhZe/GK7+PXwm1P4lz/ET9qf4y6N41/aE/a917/gnN8Pfh5Zafqv7a+mTfGDwf>8P8AwP8AB/8A4J/6O+uW3jT9p79pXxvqfifV/EV94G03wd8MrDw58NvAv9lVfzv/ALeXgXwx8DPj>38Mbf9n34KeB9OvbT9oP/gmX4u0L4W+ANO8JfCjRvHfjuDxn/wAFCE0zTLnULHS7Pw/o2p+J5tI0>Xw7N4q1aznj061SynvzLZackS/p/ffHf9tD/AImH9kfsF+d539san4a/tz9qP4U6R/xItI/4WJ5G>keOv7K0fxN/wjPxL8Tf8Iz4C/wCEY8O+EP8AhZnw6/4uZD/wlvxg8If8Ihr9fk3iN4W5BXyfgjiH>w9w+T5LgOIMtxGJxmH4o494WyHFVKksLk+YYedHA8VcUUcUoUqOavC1auEr4zC1alB1FVpVJTw9L>8O8WfBfhfEZB4c8VeFmFyHh3LeKMoxWMzDC8Z+J3BfDONq1ZYHh/NcJPD5bxtxnh8YoUKGdywdat>gcTj8FWrYZ1FWo1ZzwtH7hor4evvjv8Atof8TD+yP2C/O87+2NT8Nf25+1H8KdI/4kWkf8LE8jSP>HX9laP4m/wCEZ+Jfib/hGfAX/CMeHfCH/CzPh1/xcyH/AIS34weEP+EQ1+i++O/7aH/Ew/sj9gvz>vO/tjU/DX9uftR/CnSP+JFpH/CxPI0jx1/ZWj+Jv+EZ+Jfib/hGfAX/CMeHfCH/CzPh1/wAXMh/4>S34weEP+EQ1+vyj/AIhrxF/0MeAP/Fr+Fv8A9GR+If8AEIeK/wDobeF//i7/AAW/+j8+4aK+Hr74>7/tof8TD+yP2C/O87+2NT8Nf25+1H8KdI/4kWkf8LE8jSPHX9laP4m/4Rn4l+Jv+EZ8Bf8Ix4d8I>f8LM+HX/ABcyH/hLfjB4Q/4RDX6L747/ALaH/Ew/sj9gvzvO/tjU/DX9uftR/CnSP+JFpH/CxPI0>jx1/ZWj+Jv8AhGfiX4m/4RnwF/wjHh3wh/wsz4df8XMh/wCEt+MHhD/hENfo/wCIa8Rf9DHgD/xa>/hb/APRkH/EIeK/+ht4X/wDi7/Bb/wCj8+4a/Jz/AIKa/wDBTWf/AIJ2T+Aru78BfCLWfBWs/CL4>y/Gj4kfEj40fGX4xfCvwt8OfC3wr+MX7IvwK0qwsNK+BX7Iv7YPxC8ca/wCOPiF+2D4HsrW1svA+>jadoGnaNquqapqsltITafQV98d/20P8AiYf2R+wX53nf2xqfhr+3P2o/hTpH/Ei0j/hYnkaR46/s>rR/E3/CM/EvxN/wjPgL/AIRjw74Q/wCFmfDr/i5kP/CW/GDwh/wiGv1+Iv8AwVa8LftlftYfHT4N>fDrwv+y/r/gPx1bfsx/GX4ifCTSPD/xz8G6r8S/EugfCr/grV/wRf+I/jee7k8K/Gv8AZh034e/E>Xwh8MPhLa/Emw0rwT+194Lm1N/Fui+HPAf7RHg/4h6Ve6p4f+e4r4SzrhnIMdnmLzHg76rgXg3Xl>lviH4fZ1jYUsRjsNhJ1KGW5VxHmWOr+zjXdSpOlgcRTwtKNTF4mMcLQrTj52beG/EOR5fiM0x2Yc>B4jC4X2XtKOS+KfhjxJmc3Xr08NTWGyXh3i/NM5xtqtaEqywWBrvD4dVcVX9lhaFetT9x+DX/Bbn>4zfHv4xeGfgH8Of2bv2Y2+Kni/X/ABF4U0Pw/wCO/jj/AMFSPhDp0ninwpB8d5de8Nal4w+Lv/BC>nwN4K0DX7K5/Zd/aQ0WPRtf8RaZqN94p+BPxY8I6dbXfijwJ4j0jT8zwD+3Z+1P43/aT1H48+Cvh>n+wNrUPjrwb8Fv2XfDPwtT9ub9vHTfEXxK1jxH49+K3jz4S/Gr4O6VP/AMEqNMsfjv8AAP4geGD8>XfEfhP8AaO8CfCb4j/Beb4XfBz42fF/wL+0Ro/wh+GP7Qt9a/D37D37D37eHh79vD9hj4nfE79hj>x98E/hf8E/H3xV8W+OPHHi34q/sK6/o/gDR9f/YV+IvwQ0Pw94e0P4IfEXxT4s1H+0fFninwF8Ho>IPg94D+BXgW28C/Ar4d3l58O9M/ZX0z9hD9hD/gjz98/F/8AYQ+Lfw1+Odz8Wv2SPhX4+8AfDT4O>/wDCIeCPB2jfCjxx8FvHv7SmraP4u8IfEC58YeKf2PfDf7cHjD4k/slfBvwD+zhLrvwq/Z7/AGVf>hV40PwM8C/AD9n742/8ABYzwv8GPgrp97+0J8BvFfjr8Fh4oZ9lFfMMHlee4KjTznIPqmKqP+xMb>h50a2YuWIwGJxEaT9g6lTBZfXjLCwjjKNPnqy5sPJp+LlWYZhlFHNIZfWnh4Z1ltbJM0gqFKpLFZ>XXr4HG1cPH6xSqyo82JweHn7ehKjXToqEK0YVKkJ/eniv9oH/gpp4M8LeJPGGr/sV/sS3mk+FNA1>jxLqlp4U/b//AGr/AB54putO0LTrjVL228NeB/A3/BInxF418Z6/PbWssWjeFPB/h/XfFPiLUWtt>I8P6PqmrXtlZXHG/8Eyv+Cms/wDwUTn8e3dp4C+EWjeCtG+EXwZ+NHw4+I/wX+M3xi+Knhb4i+Fv>ip8Yv2uvgVqthf6V8df2Rf2PviF4G1/wP8Qv2PvHFldWt74H1nTtf07WdK1TS9VS1QG786/bE/YH>1j9qz9n74ffFf47aX4+8f/tn/A34B6/4hi+Cv7Nn7THjr4afsu/F/wDaLl/Zr+M/w81n4d6T8MPj>6fHf7O154B8ceMfjR4w8O2Pi349/BTxPdeMPh5NoPws/aXg+KP7N+p/FP4HePfn3/giP8G/jF8Bf>jN+0l8Ofj54Z1/wh8VF/Zk+B/jvxBofivxFB4r8Ux6d8Xv8AgqR/wXW+Lvg/UvEuvRfHn9qS5vdf>1/wV458O6/rEetftI/HbxTY6jqdzp/i74sePPFFrq/iTUergvi3HZ5iIUMbmOHr4h1ZwnhqOHw2H>UadOhi5zqUkqlXE4imp08LKOJth6UfbOjKlOo1KHj4ihGkrxi0rJqTber5dHoknq/d1eid+/9FVF>FFfqRxBRRRQAVxfxD+Hng74reDtY8A+PtH/t7wlr39n/ANraT/aGqaX9r/svVLLWrD/T9FvdO1OD>yNT06zuf9GvIfN8nyZvMt5JYn7SiuTH4DA5pgcZlmZ4PCZjluY4TEYDMMvx+Ho4zA4/A4yjPD4vB>4zCYiFShisJiqFSpQxGHr050a9Gc6VWEoSlF9OCxuMy3GYTMcuxeJwGYYDE0Mbgcdgq9XC4zBYzC>1YV8Li8JiqE6dfDYnDV6cK1CvRnCrRqwhUpzjOKa+Lf+HeX7Hv8A0SD/AMv/AOKH/wA21eYfBL9h>P9lXxf8ABj4ReLPEXws/tDxB4o+GHgHxFruof8Jv8RrT7drGteFNJ1LU7z7LY+L7aytvtN7czzfZ>7O2t7WHf5dvBFEqRr+kNeLfs2/8AJu3wD/7It8LP/UG0KvxHFeCXgxHjDIsLHwi8MI4atw1xXXq4>dcA8KKhVr4bNODKeHrVKSyn2c6tCnisVCjUlFzpQxNeMJRjWqKX7FhvGLxclwrnOIl4p+I0sRS4g>4Zo0q7434mdanRxGW8W1K9GnVeZ88KVaeGw861OMlCpPD0ZTUnSpuPa/Dz4eeDvhT4O0fwD4B0f+>wfCWg/2h/ZOk/wBoapqn2T+1NUvdav8A/T9avdR1Ofz9T1G8uf8ASbybyvO8mHy7eOKJO0oor9uw>GAwOV4HB5ZlmDwmXZbl2Ew+Ay/L8Bh6ODwOAwODoww+EweDwmHhToYXCYWhTp0MPh6FOFGhRhClS>hGEYxX47jcbjMyxmLzHMcXicfmGPxNfG47HY2vVxWMxuMxVWdfFYvF4qvOpXxOJxNepOtXr1pzq1>qs51Kk5Tk2yiiius5goorwD9p39oTR/2X/hFd/FvWfAfxA+KH/FwPgn8LfD/AMPfhavgT/hO/GHj>v9oD42fD34A/DjQtCm+J3jv4ZfD+y+2/ED4m+GY9T1PxZ498M6PpWj/2hqVzqH+iLbzAHv8ARXwB>/wANkftFf9Inf2//APw43/BLL/6ZZR/w2R+0V/0id/b/AP8Aw43/AASy/wDpllAH3/RXxB8Jv2z9>b8e/H3w5+zn8Sv2P/wBp/wDZj8beNPg/8VfjX4I1T416z+yP4j8K+LPCvwX8afBHwL8QNP0++/Zt>/ar/AGgtX0zxBpmr/tBfDm4tbXxRoegadqmnXWqzWGqz3OlTWbfb9ABRRRQB5D+0F4A1n4r/AAE+>N3wt8O3OmWXiD4lfCH4leANCvNamurbRrTWfGPgzWvDumXOrXFjZajewaZBe6jBLfzWen391FapK>9vZXUypBJ+O3hL9iL/go14M0LSNE0TUv2Q9N/s3wz4C8NX194a/aT/4KQ/Dn/hJf+Fc/Drwh8KvD>+v6/4f8AhV8R/AngqTxNJ4K8CeFtL1XVdL8LaV/aH9lQSSQLtVV/eeiv1Hgfxd4p4AynMMlyWhk9>fAZljY4/ERzHCYmrW9sqVGk4Qr4TG4Kr9XmsNhqlTDzlUoyrYehWcfaUqco/tHhv47caeF+R5nw9>w9hshxWWZtmMczxUM2wOLrV1iI0cNRlCnicDmOX1lhaqweEq1cLUlUoTxGFw+IcPa0KU4/h7/wAM>n/8ABTf/AKGn9mn/AMTQ/wCCs3/z9qP+GT/+Cm//AENP7NP/AImh/wAFZv8A5+1fuFRX1v8AxMbx>v/0KuFf/AAhzf/5+H3P/ABNn4jf9CXgnp/zLs96W/wCqk/ur8T8KrD9g/wDbl8SfEr4OeIviRqP7>K0Xh/wAD/tB/s+/GTxjrui/Gb9tL4nfErWtG+BGv+M77RfC+k6n+0NrvxNsrTTLSy+JvxAvLDRNP>n8N2t5r+rxXF9qlvCJnP7q0UV8Hx94l8ReI1TKZ59Ty2kslw9fDYKGXYatQThiHQ53iKmIxWLr15>xhhsPQoudZqjh6FKhSjGlThFfmXid4v8V+LNTIp8T0cnoLh7C4nCZfTynB18MnTxbw3tJYqri8Zj>sTiakKeDwuGoOrXccPhcPRw1GMKNKEIlFFFfnp+VhRRRQAV+R/7a8HxivP24/wBnTT/gBDoD/GHV>f+CdH/BS/RvA934l+IEHwt07QtR1n9o7/gk1pd34rtvHF78BP2otJ0jX/B+k3eoeKvClt4h+AHxS>8La74p0fRvD3irw1J4c1XVLy0/XCvxw/4KE+EvHXj/8Aai8DeBPhf4h8feEfiX41/wCCRX/BYzwl>8O/Ffwpn0e2+KPhjx14k+If/AATE0bwl4h+G1z4h+Ifwh0C38faLr97p+peDp9c+LHwv0eLxFbac>+p/EPwXZLP4j035vi/l/1bzbndJQ+rx5nWUpUVH29LmdWMGpula/tFFqTjdRadmbYf8AjU7XvzdN>Hs9r6X7X6n1D+yn8Efjn8K/2O/2bfgr8cf2ivH3xI+Pnw38A/B2z+MHxy/tHwf4w8RePfGHg++8O>6/8AEDw5/wAJJ4v+FOn/APCU+AfFP9n6t8Kv+E08T+B7H45658Lr/wD4SnWvHtt8fLu5+LNe+fDv>xbrHinR57bxX4e/4Rbx94W/4R7Q/iPommQeOtR8C6d461HwL4S8a63p/wv8AiP43+Hfww/4XP4B0>r/hLrbRtP+KHhrwpp+j6jrGn654a1nTPC/j7wv418EeGe+/z/nr6+/Xvn5/iX9uz9mX4xftNfB3W>fB/7N37Qegfse/HPW9A8QfDi3/artfgnB8XPjF8Pfg74+n0HUvip4K+C+sx/Ej4W6t8L9f8AiPq3>gf4cy6r430/xBqc+kweELDV9A0TT/iRo3w8+I3gD+T4zhjMVJ4qrRwqxWIlUqYn2MlSw8q0+apN0>cLSnN4dX/hUaUpU0k6MPip1Pc1jFcqcrKKUbq7t7OyvJpX820n1fVd/+2j8KfjF8cv2TP2ivhF+z>38X9f+Avxz+IPwi8b+GvhJ8W/DWtQeGdR8HfEC+0S6Hhe5ufFB8H+PNW8KaBqmrLbaF4r8V+DPDk>vxL8MeFtU1nXvhZrPhf4kWHhbxTpPy9+xRB8YrP9uP8AaL0/9oCHQE+MOlf8E5/+CZ+j+Obvw18Q>YPilp2u6jo/7Rv8AwVl0u08V3Pjiy+Av7L2k6vr/AIx0m00/xV4rt/D3wA+FvhbQ/FOs6x4f8K+G>18OaVpd9e/p5/n/PX19+vfPz/lJ/wT38JeOfAH7UfjrwJ8UPEPj7xd8S/BX/AASK/wCCOnhL4ieK>/itPo9z8UfE/jnw58Q/+Cnej+LfEPxJufD3xE+L2gXHj7Wtfs9Q1LxjPofxY+J+jzeIrnUZNM+In>jayaDxNqn6J4WVFLP6dF+wTp08XUheFsTJVsM41bVU1ehD2FHmhNS5ak4ypuHPVU+PGr91fXXlT1>93Tla07u717LXZH7H0UUV/SB5IUUUUAFFFfMHxr/AG3f2L/2a/FWn+Bf2jP2u/2YPgD421bw/a+L>NL8HfGv4+/Cn4V+KtS8K32o6ro9j4m0/w9468WaDq954fvNX0LXNLtdZt7OTTrjUdG1WxhuXudOv>IoQD6fr8wv8Agnf+2fon7Q8t18EPCnw58WaP4N+CX7I37FnxM8I/GXxJPa6do3x40n43H9oHwBde>Ifhp4TaE6/H8LdA1/wDZn1qy8HfE3xE+lWvxqttSuPHvwy0HVvgdd/Cv4wfGHy/xp+1v+y5+31+0>/wDBv9jT4M/tL/s//tI/AHxN8A/2lfjz+014R+APxk+HXxTbxcPg98Q/2UPh/wDC/wCC3xouvAfi>PxN9j+APxQ/4X/8AEHxD8RvhzdQ6Efjp/wAKt0f4ZeLtZ8R/AHU/jz8Hfiz738I/+Uov7Zn/AGYN>/wAE1f8A1of/AIKu+5/zzk9T8NisxoVPEHKMDTjU+sYLIM7pYiUklRdHNa+TYuCp2fO60J5LS5pN>ezVOtKKU5vmpetSxdSlkeOwHJB0sbmeWY51LvnhPLMNm2GjBRtyuFWOb1JSbfMpUYW0bP0Sooor7>k8kKKKKACvgD/gpZ/wAm6/Dn/s//AP4JO/8Ar039jevv+vh7/gol8NvHfxX/AGY38J/C3xP4S8Hf>E2y/aH/Yp8f/AA68QePvDOseMfAlp47+Ev7af7P3xW8I23jXwz4d8UeC/EGreEtW8QeC9P0jxHDo>XinRNYi0e/vLnTL1b2CCOTizLMcJlGXZhm2PqTo4DK8FisxxtWnQxGKqUsJgqFTE4mpDDYWlXxWI>nCjSnKNDDUa2IqtKnRpVKkowfZl+AxWa4/A5ZgacauNzHGYbAYOlOtQw8KmKxlaGHw9OeIxNSjhq>EZ1akIyrYitSoUk3OrUhTjKS/AP/AIJ3fFn4+/DrUf2PvBvg7xH8H5f2g/26/wDgnB/wSM028+N/>jP4VeNPEngvQPFXxH8K/8F3P2+/HXxb+Knwq0v43eFvG3x2+MHxJtvhR4h8N/F7x7L8ffhxqPxM+>PvxR8V/tP6xHbRy33wW1j6/+Nn/BWH9p/wAG/BDxV8SvhL8KvD/xe8bfsaeH/wBrXxz+3f4I8J/C>bw+fCup/DP8AZc/aV/aY/Zt8L/Enwz8QPir+3H8BtX/Z08P/ALR+r/sQ/tMeKNG0PwJ8Of8AgpV8>Qvglp1tbWHizwT48ufC3gqb9o3mvF/wk/a4v/CviD4K+PfiZ/wAG3l54IPgz4cfBTxT8JfF/7Gfx>MuPCp+Hv7P8A4g1fWPhF8JfEHgPWf2xn0g+DPgn4p1bXtU+HHgPUdK/sT4b+INS1e+8MaVo2o3l5>LJyXxH+BXx9+MfhX4Y+Bfi742/4Nj/ip4J+Cfh9vCfwZ8HfEf9iTxp448K/CPwq+neH9Hfwz8MfD>3if9sHVNI8BeH20jwn4V0ttG8K2ek6c2neGvD9ibY22jadFbfndTxo8NaVSdKrxHOnVpzlTqU6mS>cRQqU5wbjOE4SylSjOMk4yjJJxaaaTR97Dwi8QqsIVKeQRqU6kYzp1IZxkMoThNRlCcJRzRxlGUZ>RcZJtNNNOx7l+xN4j+Kfi39ub4Qa78UvH/8AwsD/AJWWfDnw6nvLPxH/AMJH4S+Fnw//AOCwn7E/>w68I+APEniLxF418W/8ACW/8Il/wiWoaf4KvNC0z4f8Ahzwl8LP+EA+FumeCv+Lfz+LvFv7/AFfg>d8FtL+Pvhz9riw/av+O37SH/AASO8Zavpvwf+OXw4l8Pfs5SeNP2a9R8aeKvjprf7IEusfE74q+M>fGPxK/aTufHviDw14J/Yx+GHw48Nq2jaLqMHhWGw0268QXGkeF/D2j2v6qeEPjx4i8Sa54Dg/sn4>La94S8b+NdX8A/8ACV/Cf4733xN/sXxFpfw68WfEb7Ne2X/CpfC2mPv0zwt9nuYf+EihvrP+19Nv>Psc9vJg74Hxe8PcyxeGwOAz2risVjMXgsFQpUsj4hlfEZhjcPl+EVSf9kqnh6VTGYrD0Z4nETpYa>h7RVMRWpUlKccMZ4Wcd5fhcRjcbktLDYbC4XF4ytUq5zkKtQwOErY/EunD+03Ur1YYTD1qsMPQhU>xFb2bhQpVKjjB/TtFFFfpR+ehRRRQAUUUUAFFFFABRRRQAUUUUAFfld+1l/wtH/hvT9n3/hR3/CA>/wDC6v8Ah2R/wVb/AOFP/wDC1v8AhIv+FXf8LR/4XL/wSz/4V/8A8LJ/4RD/AIqz/hAf+Es/sn/h>Mf8AhF/+KiPh3+0RoudS+zA/qjXgHx0/ZO/ZY/ag/wCEW/4aX/Zp/Z//AGiP+EH/ALb/AOEK/wCF>6fBv4dfFv/hD/wDhJv7I/wCEk/4Rb/hP/DniD/hH/wDhIP8AhH9B/tv+yfsn9q/2JpH2/wC0f2bZ>+T5mc5d/a+V43LfaxofW6Xsvaype3jD34yvKiqlH2kXy2cfawum/eRdOfs5xna/K72Ts/vs7fc/Q>/Jf/AIJa/wDDen/C0f2hh8f/APhPv+FK/wDCffFnafjz/wALl/4WifGp8RfD3/hVv9jf8LRz4T/4>T7/hEz8Xv+Gw/wDhjvP/AASZ/wCEiP7Mn/DrnOmn9rYNp/8ABQv4H/Cv49/tvfseeFPi38GfA/xu>8P6R+yP+2t4itvD/AI3+Bngj9oj/AIRvf+2B/wAEi/C3izxx4U+HHj3wB8TtHufFuhfDLxT48gst>VtvBusapp+l6nrAtYJIbm5jn+1f+HTv/AASy/wCkaf7AH/iG/wCzr/8AO5o/4dO/8Esv+kaf7AH/>AIhv+zr/APO5r84qeGFaWLxeMw/EU8BXxGV5pl1Crl2X1sDiMFUzDKMZldLHYfFYbNqeJpYrBSxU>cVSq0alCv7ShBU8RQqcteHs5XnFLL8wy3GV8vo5hQwOY4HG1sDi/ZVcNjqWExdDE1MHiKWIw2IoV>KGKjRlQqwrYevRlTqSVSjVhzU5fCeh/8E1P2P5viz4C0u9/4JmfsaP4NvNF0mTdd/wDBPr9nO1sf>EGjy/E34raV/wkvjV/8Ahm6y0/QfGt/8INK+Hni/xH4f1D4sfA668GeItSaTR/hV451ib/hSt5F+>wT8N9D+CP7Z37SHhn9mD9lr4I/Bv+0/+CfH/AATE134z+CbH4eXH7GujT/GGb4q/8FLLDxP4pt/A>/gn9nx9F8U6nqx0630jUvFdho1jpf2Tw7pWkaTqerWmmi00b7x/4dO/8Esv+kaf7AH/iG/7Ov/zu>a+gPgX+yd+yx+y//AMJT/wAM0fs0/s//ALO//Ccf2J/wmv8Awov4N/Dr4Sf8Jh/wjP8Aa/8Awjf/>AAlP/CAeHPD/APwkH/CP/wDCQa9/Yn9rfa/7K/tvV/sH2f8AtK887uyPgPPsmqTcvETifHwqQx1N>zxsqeOxNKGJeS1MPLDPNqmZ5fDEYarlmNputiMsxSlg83xFDD0sHiKbxtf6jOeNckzaEFHgLhzBS>pywdRQwkamDw9WeHjm9OvHELK4Zbjp0MRTzDB1FSoZjhnHF5XQrV6mKoTWDo6v8Abv7Rf/RK/gp3>/wCa++OvfH/Ntf8Au59MnrtG4/t39ov/AKJX8FO//NffHXvj/m2v/dz6ZPXaN3tVFfRf6vZv/wBF>1xV/4R8Ef/QceD/b2Vf9EVwz/wCFfGX/ANFp4r/bv7Rf/RK/gp3/AOa++OvfH/Ntf+7n0yeu0bj+>3f2i/wDolfwU7/8ANffHXvj/AJtr/wB3Ppk9do3e1UUf6vZv/wBF1xV/4R8Ef/QcH9vZV/0RXDP/>AIV8Zf8A0Wniv9u/tF/9Er+Cnf8A5r74698f821/7ufTJ67Ru/Gb/gnd+yv8ePiR+xv+z9+0fcf8>FL/22vDXxE/bC+Efwn/a5+N02g+A/wDgnHqUGv8Axi+PPwr8D+L/ABZeLq/jr/gn/wCMvGt14f8A>DtrPo/w7+GWg6/4s123+Gfwc8FfDn4QeDpNL+Hnw+8H+HtK/oDr4A/4dO/8ABLL/AKRp/sAf+Ib/>ALOv/wA7mvMzfg3Ms1wkcJW4uzHFwVenXazjKOHcbTg6cKsEqNLLsrySClP2t5zxH1qS5IKj7FSr>e148XmmExEqUsNkWW5V7NVFP+zcRnUnX53TcfbPNc2zVr2XJL2aw/sL+1m6vteWl7P8ANn9oD4O/>tbfCb9qK1/4U7+1Z8fP2nf2ltf8A+CRX/BWv/hmP/hePhz9i3QP+EI+OelfEP/gm/wD8Kz/4Rf8A>4Vd+zb+z34Bu/wDhJfH2peE/7b/4XYfF/g+D+wdJ3/2Dos/ir+3T/jml/wCahf8ADor/AIT7/meP>+GrP+GZf+Gov+Ew/5mX/AIaS/wCGn8/tLf8AC/P7aF7/AMLi/wCGh8/HP/hYf/CRf8Laz4+PiDf9>J6P+yd+yx+y//wAFRf2XP+GaP2af2f8A9nf/AITj9gb/AIKH/wDCa/8ACi/g38OvhJ/wmH/CNftD>/wDBLn/hG/8AhKf+EA8N6B/wkH/CP/8ACQa9/Yn9rfa/7K/tvVxYCH+0rwT/AEL+yxDJ8Wv2n/2j>f2y/Bw+0/AH4vfAP9k/4DfBrxddf6O3xeH7PHxD/AGxviB4s+NPgC1Tz/wC1PgD4w/4af8OeHvg9>8RrybTT8X/8AhCPF/wATfAWja38AfEvwS+MXxf8Ag6XCWJq8RLhpY7FU6WBy2OKxGb5ZhoZdBvEV>atWjRxOGoudHlvOUMNBVoyU/rddKftaip4OulRVbli3KfKqdRufwqCbi3Z6297TbljpZX/nz8f8A>/Dr/AP4ao+O//Dtr/hgj/hrX/hgjRv8Ah1d/wwJ/wzx/wsT/AIbn/wCFh/Gj/ha/2v8A4ZoONuP+>GIf+E1/4aX/4s9/wy1/w1R/apP7Jv/DxLd/Vf/bv7Rf/AESv4Kd/+a++OvfH/Ntf+7n0yeu0bvaq>K/RsHwnjMDh40MLxbxDhLSTm8NDJK0KvLRoUY3p5zk+ceylejKtUlhpUPb18RWqVlP8AdKlpgszw>uFdZ4nIsqzb2nJyf2hVzmk8PyOo5eyeUZtlXN7Xnip/WPb8qpU1S9ner7TxX+3f2i/8AolfwU7/8>198de+P+ba/93Ppk9do3H9u/tF/9Er+Cnf8A5r74698f821/7ufTJ67Ru9qorp/1ezf/AKLrir/w>j4I/+g47/wC3sq/6Irhn/wAK+Mv/AKLTxX+3f2i/+iV/BTv/AM198de+P+ba/wDdz6ZPXaN3mHxa>1b40XPh/wtB4s8AfC/RPD7/Gn9nX+0NT8O/F7xX4o1m2C/H/AOGj2n2PQtS+CHhCyvvOvVtbe4E/>iLTvstrNcXkZu5baOxu/rmvPfih4M1Hx74ROgaPrdl4d1a28T+APFml6vqWiT+I9Ot9R8AePvDPj>yxh1DRbXXPDdzf2V/c+G4tPuo7fXdMnSC6kmhuRJEqN4XFHC+f4rhniLC4PivifNsXicizehhcrq>UeB6EMyxFbL8RToZfOu+GcuVGGMqyjhpVXmGBVNVHN4zDcvt4e1w3xLkeG4iyDE4rhjhvLMLh86y>uvicyp1uMq88voUsdQqVsdCiuIse608JTjLERpfUcb7R01D6piL+xn8+LHr8v7MXxji8LXXxCsde>k+IX7UMen33wpsNE1X4hWbv+0R8UFmuvDGl6/qWjW2pXtvbGaaaw03WNK8U3lkl1b+CtSsfGMmhX>UXzF4u1j9oy98A/Ddbjwh8drDwDoHif9pjR9Ym+G2r/GLR/iZ8RU0/wjrcv7P/i+5t9fvfiH8e/h>/ZeIvFk2p2NrpHju68VeFtHu7HQ9U8YWU/hS78JaPF9O6l+zHqOs6jqGsaxov7HWq6tqt7dalqmq>al+x3PfajqWo308l1fX+oX118eJbm8vby5lluLq6uJZJ7ieSSaaR5HZjS/4ZQ/6lb9i3/wAQx/8A>x61+DcScDeJueYfLsLhuGc9yqOW8JcP8KKpguMuF4Usxo8OZ7lueUa2My/E/XqFDBZzPLYYPiLKs>LWjWzTLZwyzEZvUwVKpSxP7Xw9xn4dZNXx2JxHEWS5nLMOKM84mdPGcJcSTqYCtxBkuPyatSwuOw>7wdatjMohmE8XkOZ4mlKlluYQnmNDKoYyrTq4fF/Zw8ZfE+6+MvxRj+J2lfGnT9M8ceCv2dtT8A2>fjLwx411Dwzo+sW/wcGrfE+xbXtO8HaF8OPCmtQ+IrlbXxQkWm+B7XWPFkUthZ6FBqcS6Ra7X/Nc>v+70v/gdlH/DKH/UrfsW/wDiGP8A+PWu18IfAfxF4b1zwHP/AGt8FtB8JeCPGur+Pv8AhFPhP8CL>74Zf214i1T4deLPhz9pvb3/hbXinTE2aZ4p+0XM3/COzX15/ZGm2f2yC3jyPdyPhvxOp5dwtkGd8>MZhiaGTeJ8eNp5/iuJOH8wx7wuacU5hnWYYXH0lj8P7Wllf9v5jUw2IwMfaLLcvwOV4fKK1dPET8>XOeIfDqeP4lzzJ+IsDh6+beHD4PhkeG4fz3AYGOJyzhrL8pwOJwVV4Gv7OrmP9iYCniKGMl7N5hj>cZmNfNKVBqhD6dooor+oz+bgooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo>AKK/kC/YS/YR+FnijR/+CRnw9uf2Tf8AgkB4i+GX7Rn/AATA+HP7VPj3V/il/wAEr/DnxH/aO1P/>AIUd4E/4J8eFvi3oeu/HST9onw74f8UfED44eIP2pvFnjDTPi1rPwdl/4V/daLp9r4m8C/F+9v8A>Utbl/R/x98OP+DfD4aaJZa/4o/Yg/YgkttU8QfGTwnoum+E/+CaOkfEPxV4h8VfAH9rj4X/sI/FP>wz4Z8E/D79m/xP4x8S+INE/ax+M/wy+EGjaNoOhajqPjnUfFVt4l8BW3ifwRY6t4m08A+/f2kP2H>vCf7UHx++BPxX+IfjbX0+G3wo+EX7Rfwh+IXwG07TtOTwr+0V4Y+PvjP9mXxs/g/4ta/cNNq1z8I>NM1b9m3SpPHnwo0a30/Tvjlp+rR/Dz4pa3rPwKvvit8HfjF9w1+ENz8Mf+CBEHhXRvEtv/wTy/Zg>1rV9Z8QeJvDJ+D3hb/gkZ4k8YftQeHNR8G6d4T1rxVc+P/2RfCv7JusftR/DPw/oGh/EX4Ua/qni>z4ifCDwv4VtfD/xq+BGuyayNI+OnwivPGh+0V+xX/wAE24PD/wCyLpX7LX7AX/BKDVNX/bc+MFt8>OPhT8dfE37EHwG+N3wa8OeFU/Zf+Pv7W1v8AE628GfDuT4WXPxl8P+OPBP7P914L8Jr4b+NXgLTr>Wf4j6N8Tk8QeKNI8JyeBPGkRpwjKc4whGdRp1JRilKo4xUIuckk5OMEopybailFaJILvvtt5H7vU>V+IP/DAv/BPv9nL4Wf25+2L/AME0v2APiV4gX4gf8IjoXjD9in/gkZ4n+KP/AAmuj6p4c/4SfTPE>Wv8A7Nnwt+DX7UfxN+Cn9jXtr4n8DarPefEn4s+BNT/4Rvwr42uPiL4Q8QfF3T/gt4F8f/aF0D/g>gl8HPhL8cPH/AIF/YJ/4JwfGzxJ8K/2YPiX+0l4O0nwn+yJ8FE+Evxcn8D/s8a1+1D4e+D/hn9p3>R/gV4s+By/GDx78DtLs/jVo3wp0vxL4l+Mq/s8atbftHWPwt1n4NiLxVc2B/Q9RX5Qf8EufBnwa8>BeJv+CkHh79nz4V+H/gn8G5P23/hn4m8C/C7wz8IZ/gDp3hPTvHH/BLn/gm342vLa5+C994U8Dav>8NPEGoav4h1HWPFnhPxF4O8NeKtL8VajrMXivRrHxIdUgT9X6ACiiigAooooAKKKKACiiigAoooo>AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA/nB/YZ+M/ww+F3ws/4JdeLPil4E>/b/8GfE39kT/AIJgf8MdfEX4Sf8ADpX/AIKa+Itvjv4keHP2GdS8XXn/AAnvh39l7UPD5/4Vz4g/>ZI1Dwz9n0K28S6P4v/4TD+2dM8T2Nl4fgj8SfEHi7xcnxI8A/FH4x+C/2fP+Cj/wi+K2r/tv/AX4>k/sb/AP43f8ABLH9vPx5B+yH8GvGn/BQv9hf9tf9u7xt8VdK+D3wUtdD+K3iD40/tR/An4q/tWeI>/A1t+2D8TJ7T4NeHfhN8If2d9c/Z88U+IvHvwqH9jtFAH8oXxT+Ev7Ovxl8Rr8cPitonxA+OX7TW>v/ED4q+NfH5/aU/4Nq/+Cpvx3/Y2n/4Wp8LP2RfgveXvww/ZV8R+D9P+IHw5+IHh74f/ALCv7P8A>Y6D4/wBa/an+I3kX3iP9ox5fDkmi/FfwVoHwa+3/AIifGr4DXXwk/ZM8HfBNv23/AIefET9iHxB4>U8TfAPxf45/4Id/8FJPFPwzn1HQf2ePif+yrqNt8SfgR8D/2TP2XvDdx4f1D4N/Gb4gS6H4T+CXi>H4B+FfBfxCj8E6xoGjR/Dvwte/CjxH+71FAH80Px88SeGf2mfCvw9uvjx4o+MHx++Ing/wAQfEHU>L7wB+0X/AMG2P/BUb4w/sGJp3jfTvh5pWl6r4J/Y+vPA+geNtH+MHw6tvhmH+Hfxr+JP7Uvxj8Ve>FU+PP7XPhvSbW0+Hfxk8C+BvgpwHhP4b/Aax+Evhn9nnxn8YP+Cj+rfBaL/gnBo3/BO/4iJ4B/4I>h/8ABST4cfFv4heC7D9ni2/Z7ktL3x7cfsreNPBN18H/AA5cz+Lf2hvg34I+Ifwh+J/x9+CH7Q/x>H+KC+B/2tYv2afit8V/2ZfHf9TtFAH5gf8E0tW8Y+MdU/bz+KXi7QfiBp3/C1f2v/h34j0fxL4//>AGaPjt+yN/wsr/hFf+Ccf7AHwk8b+P8AwV8Cv2kLC1+LXg74f3/xa+GvxF0Lw5Z+ItQ8VfZf+Eev>NMg8a+L/AOzpPEF/+n9FFABRRRQAUUUUAFFFFABRRRQB/9k=>>------=_NextPart_000_000E_01C07A54.17E37CC0-->
Message 10 of 12
(16,370 Views)
Mike
Message 8 of 12
(16,366 Views)
> "Keith Fuller" > > schrieb im Newsbeitrag
> Mike
May be it's more elegant, but below is ~380 times faster.
Cheers,--
Sergey Krasnishov
Moscow, Russia
Message 9 of 12
(16,366 Views)
