Hex & Reading board VI
see attached VI
I've generated a code (6065780000000699) onto a board which i hope this vi will read and confirm is connected, instead i'm getting it read as, 7FFFFFFF which is NaN. therefore wrongfully confirming i've no board attached.
any idea?
Message 1 of 18
(3,781 Views)
Hi dhanna,
try to convert string to num like this:
Btw. attaching a VI that contains a missing (for us) subVI is pretty senseless…
Message 2 of 18
(3,770 Views)
but it should be reading from the sub vi 'ADC selector' which ia an array, where that code is kept, im hoping to hvae about 20 different codes in here for different parts.
Message 3 of 18
(3,763 Views)
Hi dhanna,
no subVi, no answer…
Message 4 of 18
(3,738 Views)
'ADC number' i meant to say, its in 0 of the stacked sequence structure?
Message 5 of 18
(3,735 Views)
Hi dhanna,
again: WE CANNOT SEE YOUR SUBVI!
As long as we don't know anything of your subVI we cannot provide any more help!
Message 6 of 18
(3,729 Views)
can i ask, what you mean by not seeing it? the sub VI's not loading (like the ? symbol) or what?
Message 7 of 18
(3,716 Views)
Yes, you attached Untitled 1.vi, but you did not attach connect1.vi
Message 8 of 18
(3,710 Views)
Message 9 of 18
(3,705 Views)
Hi dhanna,
the subVI "array.vi" is missing!
You get an I64 array from this (missing) subVI…
Message 10 of 18
(3,695 Views)
