Hex string cksum XOR
I try to calculate cksum for hex string. but I can't get right result. I use MS calcuator, I got result "cksum = 51" and I use labview 8.5. I got the result " cksum = 11. Can anyone tell me what I did wrong?
Johnny
Message 1 of 8
(7,502 Views)
It looks like you are using OR instead of XOR.  I recommend building the bytes into an array and use a FOR loop and shift register to XOR all of the elements together.
Nevermind, just started looking at the VI instead of the picture.  This is actually a Decimal vs Hex problem.  Right-click on your constants and select Visible->Radix.  You will see a little 'd' next to your numbers.  This shows that your constants are in decimal notation.  You can click on the 'd' and choose Hex.  The radix will now display as a 'x'.  Fix your constants to be what they really should be.  Do the same thing to your output indicator to show the value in hex.
Message 2 of 8
(7,496 Views)
Accepted by topic author Jlin
The math in my head suggests that you probably are entering decimal values into those constants and not hex values.  Right click them all and set the display format to Hexadecimal (and show the radix!).  Do the same for your indicator.
Message 3 of 8
(7,488 Views)
yeah, It works.
Thanks, Darin
Johnny
Message 4 of 8
(7,473 Views)
JIN @
HEY CAN U UPLOAD UR UPDATED VI PLEASE..!! IM FACING SAME PROBLEM
Message 5 of 8
(6,887 Views)
I'll give you a kudo since you didn't get a solution.
Bill
CLD
(Mid-Level minion.)
Message 6 of 8
(6,884 Views)
Hi minakshi,
there is a VI and you can read above how to change this VI to get a working solution! What else do you need?
All you need for your other thread is the XOR function as already suggested here
And please stop SHOUTING OUT LOUD - it's considered rude behaviour in public forums!
Message 7 of 8
(6,879 Views)
thanks billko.! i will check out this.
Message 8 of 8
(6,876 Views)
