Hexadecimal string to Hexadecimal number
I need to convert a hexadecimal string into a hexadecimal number to use that value as input to a Modbus block .. How is it done?
(4,026 Views)
String >> Number/String Conversion palette.
(4,012 Views)
The built in function "hexidecimal string to number".
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,010 Views)
Note that what you want is to "convert a hexadecimal string into a number", not a  "hexadecimal number".  The output is a number, stored internally as binary, and the number base isn't specified until it is converted back into a string.
(3,984 Views)
Your question is very ambiguous, because all we know is that you have a string and probably want another string.
(The word hexadecimal is a visual format, not an internal representation).
You need to be careful to make a distinction between internal representation and formatting for human consumption.
You could be talking about:
  1. A binary string possibly containing all 256 possible byte patterns (00..FF) with the string indicator set to hext display.
  2. A hexadecimally formatted string containing exclusively the 16 characters 0..F (and maybe some spaces for readability).
  3. A numeric with the display set to hexadecimal formatting.
  4. etc.
So:
  • What do you have? (what is a hexadecimal string????)
  • What do you want? (what is a hexadecimal number????)
Easiest would be if you could attach a simple VI containing diagram constants of your actual data and what you want out of it.
(3,966 Views)
