Hexadecimal to decimal with point
Hi
I am trying to convert one hexadecimal string to a number, but I want to appear the number with the corresponding comma or point.
I use the function Hexadecimal string to number, to convert the 348E hexadecimal string to number and I want to see 134,54, but instead of that the indicator shows the number 13454
How can I get the number 134,54?
Best regards
(2,287 Views)
Accepted by topic author labview99
Hi 99,
This process is usually called "scaling": when there is a factor of 100 (or 0.01) to be applied on your integer value then you just need to multiply your integer value with that scaling factor…
(2,267 Views)
38
Spoiler
My prediction on how long this thread is eventually going to get.  😉
(2,255 Views)
Thank you so much GerdW
Best regards
(2,246 Views)
