Hi, Can some one tell give me a hint how to record a pushbutton stroke sequence, ie. if there are three buttons and the buttons are pressed in 2,3,1 sequence, the sequence will be stored somewhere ?!
If there are three buttons, pb1,pb2,pb3 ...
Buttons are pressed in 3,2,1 sequence , how to record that sequence ?
RoN
(2,567 Views)
(I recommend next time to keep the post title short and place the question in the body of the post.)
Use an event structure and append a value to an array kept in a shift register. See how far you get.
(2,555 Views)
My bad , first time poster, so got confused.
I am an absolute beginner in Labview, so still pretty confused. Thanks for your reply.
I tried to run it through event. But I am not sure about the usage of the stack register. I have attached the vi file with the post.
Can you point out the problem please?
RoN
(2,537 Views)
Accepted by topic author RoN_84
See if you can use any of this....
(2,531 Views)
Thanks a lot for all your efforts. Currently trying to understand what is happening in the code.
Thanks again
RoN
(2,528 Views)
