08-25-2011 11:41 AM - edited 08-25-2011 11:41 AM
You did not use a feedback node, thus the broken wire. Also you should append to the end and not to the beginning of the existing array (for performance reasons).
I don't see a toplevel while loop. Are you using continuous run(don't!!)? Are you calling this as a subVI? It would be so much easier to attach a VI instead of a picture. Please do so.
08-25-2011 12:36 PM
Appending to the end and not to the beginning made the difference, I don't know if I done any thing else. I haven't tested the graph part yet I will try to do it later. Yes I can show the .vi
