Hi, I'm developing a application thats need read and log a large tag database at
Hi, I'm developing a application thats need read and log a large tag database at period of 1 second. My system have actually 1200 tags and when I try to increase the number of tags my system slowdown and not update at requested period anymore. I'm using NI OPC Servers to read data of 4 different PLC's. In the SVE I've created an IO Server to bind variables and all variables are located in a single process. All variables are logging alarms and data. The Log Deadband and Update Deadband are set to 0. My machine is a DELL Precision T5400 with Dual Intel Xeon Quad Core with 4GB of RAM and Windows XP Sp3 installed. Bruno Costa Automation Enginner
(2,346 Views)
Duplicate Post
Why did you create an identical post under a different username?
You'll have to be patient.  It is the 4th of July holiday, so the forums are going to be less active than a usual Monday.
(2,344 Views)
