Hi I see you are very good NI LabView and/or Vision Builder AI 3.0. I'm student and doiung my presentation and have some trouble with technical part of work. If you know good one or both programs could you help me ? With best wishes,
Hi
Is there  someone very good in  NI LabView and/or  Vision Builder AI 3.0.
If you know very good one or both programs can you help me ?
With best wishes,
Message 1 of 26
(5,266 Views)
... contact an NI Alliace partner company and they'll discuss the project and associated cost.
Good luck.
Jim
Message 2 of 26
(5,258 Views)
  • As a first step, I recommend that you don't place the text of the entire presentation on the title slide of your presentation. Keep the title short. (Same applies when asking question here in the forum).
  • Then you should make up your mind if it should be about LabVIEW, Vision Builder, or both (you said and/or).
  • Then you should explain what you mean by "techical part". Ask specific question and you will hopefully get specific answers.
  • If this is too complicated, maybe you should make the presentation about something else. Who gave you this assignment?
  • What is the field of your studies (vision, engineering, programming, etc.).
  • Who is the audience? What do they already know about the subject? What should they learn about it?
Message 3 of 26
(5,253 Views)
I'm preapearing my paper work for recognition of errors using algorythms.
This presentation is about algorythms that can do this.
And practicaly I must do one or few photos with one ar boths programs to find error.
Please find attached picture sample.
As i undestand I can not  compare two pivtures, becouse ezch picture of sea container is unique.
I'm student and presentation would be to my classmates.
We studyiong IT enginering.
Message 4 of 26
(5,241 Views)
What is your definition of "error". That could mean anything!
(e.g. a damaged container? No container present? A container of the wrong color? A container of the wrong size? A container with the wrong serial number or company logo? A container with the doors open? A container that is upside down or tipped over? Container not visible beause it is at night and there is no light? No signal from the camera? etc. etc.)
Message 5 of 26
(5,192 Views)
If you are a total beginner in both software, I would recommend you to learn Vision. Back in the university, I remember, it took only a few days to reach a level in Vision Assistant (that time I did not learn/use LabVIEW) to use it for scanning electron microscope pictures to create geometric statistics of dark coloured carbon precipitates (total size, size distribution, elongation, etc..).
There are many different methodes, this is not a simple topic. Many things depend on your actual task. I would recommend you to search the internet and read many resources.
Just after 2 sec google:
http://physics.ucsd.edu/neurophysics/Manuals/National%20Instruments/NI%20Vision%20Assistant%20Tutori...
http://zone.ni.com/reference/en-XX/help/372916P-01/nivisionconcepts/golden_concepts/
http://zone.ni.com/reference/en-XX/help/370281W-01/nivisionlvbasics/inspect_image_for_defects/
Message 7 of 26
(5,175 Views)
It is not going to come quickly!  You can't read one source and expect to do sophisticated Visual processing with a token effort.  With diligent studying, preferably with someone who can help and direct you, it will take you maybe a week of work if you already know LabVIEW.  If you are also a beginner with LabVIEW, it will take several weeks of serious work.  However, if you are willing to put in the effort, you will have a very useful skill ...
BS
Message 10 of 26
(5,080 Views)
