Hi am using the California instruments power supply but my code does not work except when the highlight execution is off?
Hi am using the California instruments power supply but my code does not work except when the highlight execution is off?  I get the following error
Error -1073807339 occurred at VISA Read in California Instruments iX Series.lvlib:Read Single Voltage Measurement.vi->California Instruments.vi
Possible reason(s):
VISA:  (Hex 0xBFFF0015) Timeout expired before operation completed.
(2,873 Views)
...highligh execution in ON***
(2,872 Views)
HI
Mark Ramsdale
(2,870 Views)
HI
Mark Ramsdale
(2,870 Views)
You are splitting your references to the instrument.  I suggest putting them in series, this may clear up your issue.
What is the timeout set to in the init VI's.  ( I did not have the subVI drivers to look at).  On the surface it would seem one call has the instrument and another call can not get access, and thus times out.
Also, when you put the VI's in series you do not need to use a sequence structure.
Mark Ramsdale
(2,867 Views)
