Hi, i unable to read data from data logger (Graphtec GL820), and getting an error
Does GL820 support IDN query?
Santhosh
Soliton Technologies
Message 2 of 9
(2,163 Views)
Hi, sorry i new the forum. it does work from NI MAX
But error start from VISA read block
Message 3 of 9
(2,153 Views)
So, you need to watch this first - https://labviewwiki.org/wiki/VIWeek_2020/Proper_way_to_communicate_over_serial
Santhosh
Message 4 of 9
(2,140 Views)
I am not finding a programmer's manual for your device (I didn't spend much time searching either).  So I will trust that your command it correct.  However, you likely need to concatenate an End Of Line character(s) to your command string before it goes into the VISA Write.  Instruments tend to look for that Carriage Return and/or Line Feed to know when the command is complete.
Message 5 of 9
(2,107 Views)
Your write string is not correct.
Are you sure you are adding a New Line or Carriage Return to the end of the string?
No one is able to debug your picture.
Message 7 of 9
(2,088 Views)
Change the display on your command string constant to '\ Codes'.  It also helps to make the display style visible (right-click->Visable Items->Display Style").  By default, the display style is 'normal'.  So you are not sending a Carriage Return and Line Feed, but literally '\', 'r', '\', 'n'.
Message 8 of 9
(2,058 Views)
Agilent Technologies / Keysight Technologies 34970A Data Acquisition Unit - Instrument Driver is readily available.
https://tmesystems.net/
Message 9 of 9
(2,051 Views)
