Hi,x scale time format shows 00:00
I have the data in microseconds for x axis. When i change display format to  absolute or relative time, it shows 00:00:00. how do i get the correct time format starting from 0 mcro seconds,?
Thank you,
Rajni
Message 1 of 11
(3,501 Views)
You want time increment in micro-seconds?
Which LV version are you using?  Is it the LV-RT?  And what OS are you running the VI on?
Best that windoze can do is milli-seconds.
R
Message 2 of 11
(3,479 Views)
I set the axis to SI notation instead. I assume you are using a graph.
Message 3 of 11
(3,469 Views)
I have the data graph y axis and x axis. The data is captured in micro seconds. they are big numbers, so dificult to understand the time in graph x scale. so i am trying to use the time format. i need something like this.
0:00:01     0:00:02   ... 0:01:99 ... etc...
if not possible what is the better way to represent this?
Ranjith
Message 4 of 11
(3,452 Views)
Back to my original questions:
What OS are you running this on?  What hardware are you using?  What resolution do you need to show on the graph?  is it also microseconds?
R
Message 5 of 11
(3,448 Views)
I think the way you want to represent microseconds is confusing. Most people are going to think the xx:xx:xx format is hours:minutes:seconds. I think it would make more sense to represent microseconds as scientific i.e. n.ne-6
Message 6 of 11
(3,444 Views)
If you use SI notation, it will produce the correct short hand notation for the differ values, thus for 5 usec will appear as 5u
Message 7 of 11
(3,428 Views)
You're right. SI would be better.
Message 8 of 11
(3,423 Views)
Seems to be SI notation is correct for my purpose.
How do i change the format of SI Notation? currently it shows 1M 2M etc.. I want to represent it in milli seconds or micro seconds.
Thank you,
Ranjith
Message 9 of 11
(3,411 Views)
Go to the graph or chart properties, Display Formtat. Select your axis and select si notation
Message 10 of 11
(3,393 Views)
