Hidden Controls
It's ok. I also dont want to attack you nor NI.
But i am unhappy with the kind of implementation of the "hidden control" feature.
If i set a control to the attribut hidden in the designer, ok it is my problem. Its not nice that i never can't set its unhidden easily...
But i also set controls hidden during the runtime. After the end of the application these control are now hidden in the designer too.
I have a big labview project, there are a lot of controls. And for a lot of them i have to look in block diagram, thats very confusing, because the search is difficult.
What i mean is, it would be better to show hidden controls in the designer too, maybe as gray out or something like that. It's not nice to design with invisible controls 😉
I understand it seems that this problem doesn't have high priority for NI, but i guess a lot of LV users are unhappy with it...
Message 41 of 52
(2,926 Views)
They did implement this for clusters. They should also implement it for panes...
Wiebe.
Message 42 of 52
(2,919 Views)
Here is Warren Massey's version, with some small modifications.
I've added a highlight button, and a find terminal button. We have to use scripting functions anyway...
I also modified the window sizing a little bit, since we can use autoscaling controls in panes now. This makes the code a lot easier to read.
Wiebe.
Message 43 of 52
(2,913 Views)
Thank you for this VI.
But it has an error's when i open this VI.
It looks like a conflict because of two different classes.
If i want to fix this error by using a typecast, i can't reopen this VI, because the main dialog of this VI flashs for a short while and it were closed very quickly.
Message 44 of 52
(2,906 Views)
What LV version are you using? It was created in 8.6.1, and then saved back to 8.0. Then I reopened it in 8.2 and 8.6.1, and it worked just fine. Apparently, some new version changed the Controls[] property of the pane and cluster to Elements[]... It shouldn't do that, if you'd ask me.
If you create a new VI, and then put the VI in it as a sub VI, you'll be able to edit it at will, without the VI closing itself. Be carefull though, if you have the VI in the diagram, LV did crash when I activated it from the menu. It did not crash when I put a disabled case around it.
Wiebe.
Message 45 of 52
(2,893 Views)
This I agree with. Enough to create an idea for it:
Show hidden controls as "ghosts" in edit mode
Also, have you seen this one?
___________________
Try to take over the world!
Message 46 of 52
(2,878 Views)
I'm using LV 2009 SP1.
It seems that Panel and Cluster are two different classes now
Message 47 of 52
(2,860 Views)
@tst
Exactly that's what I want to have for it. Is it so difficult to implement (for NI) Smiley Mad
Message 48 of 52
(2,857 Views)
They always have been. The two have nothing to do with each other.
I actually understand perfectly well why this method was implemented for cluster controls (regardless of whether or not it should have been added to the VI) - controls inside a cluster don't have a terminal on the diagram, so the only way to manually make them visible had to be through the cluster.
___________________
Message 49 of 52
(2,819 Views)
Who said it's difficult? It's possible they just never thought of it.
I certainly haven't thought of it until now and I can tell you that one of the votes on that idea is from the guy who created LV in the first place. I assume that if he would have thought of this before, it would have happened by now.
___________________
Message 50 of 52
(2,817 Views)
