Hide / Disable Front Panel
Long story, long:
I created a small utility as a VI.  The utility accepts command line arguments, reads a file, outputs (using .NET) to the console, and then should exit.  The front panel is blank, and the program should complete in a fraction of a second.  In fact, I bet the "application" overhead takes more time than the actual program.  I would have coded this in another language, but I can only read the cluster written to a binary file with LabVIEW.
Environment:
Windows XP, LabVIEW 8.2.1, .NET Framework 3.5
Long story, short:
How do I prevent a LabVIEW program from displaying the front panel and showing up in the Taskbar?
(8,013 Views)
How are you calling the VI?  If it is a subvi, then as long as the Windows Appearance is set to not show the front panel, it should not be shown.  If it is a main VI, how will you run it if the front panel is not showing?  You could use a property node and set the front panel to run transparently.  Or you could set it to run transparently in the Windows Appearance screen.
- tbob
Inventor of the WORM Global
(8,012 Views)
My project has only the main / startup vi.  I build the project to construct the EXE.  I had hoped it would open (without showing the front panel), complete, then exit.
Right now, I put my code inside a flat sequence with a boolean true coming out to a Quit LabVIEW node, but I still see the blank front panel momentarily.
Message Edited by StevenATK on 04-14-2010 09:39 AM
(7,985 Views)
Hi Steven,
you could:
- move the window outside of the screen
- make the window very small (1×1 pixel)
Every program being run in Windows will show up in the taskbar, and usually they also show a frontpanel/window...
(7,965 Views)
Accepted by topic author CodeSDz
There is also an option to close just the front panel, try it with the 100% transparently option also
Rodrigo Cuenca
www.cidesi.com
(7,958 Views)
I guess there's no such thing a LabVIEW console application.  Thank you all for the various tips.  I was able to reduce the time the front panel was present and move it out of the way.
(7,946 Views)
Hi Steven,
your guessing right: the main VI of an executable has to have a front panel.
You may hide VIs when installing them as service, but that won't help you here...
(7,934 Views)
