Hide Inactive Points
I have a simple thermocouple data acquisition set-up with two cFP-TC-120 which gives me a total of 16 points.  Currently my program is written to display all 16 points represented as a cluster and a graph on the front panel.  Is there a way to allow the user to input the number of channels being used and have all the inactive channels hidden?
Thanks.
Bobby
LabVIEW 2016 - Windows 7
CLAD
(3,830 Views)
This can easily be done using the "plot>visible" graph's property (see attachement).
If you want the visible channels to stay in a straight order you have to create a new cluster containing only the element you want to display.
Nicolas
(3,802 Views)
Hi Bobby,
I am not quite sure where or how you would like to define active channels, but I wrote up some code for you that will allow you to input a channel number and either display it or hide it on the waveform graph. I hope this helps.
Steven
(3,801 Views)
Thanks for the repsonses guys but I think I was unclear as to what exactly I'm trying to achieve.  My system is set up to aquire 16 thermocouple points.  The actual set of points varies depending on the test so not all 16 points are used all the time.  The points are represented on the front panel digitally in a cluster and graphically.  Is there a way to allow the user to control what points are read?  For example if the test only calls for 12 points, is there a way to only show the first 12 points in the cluster and the graph?
Bobby
CLAD
(3,781 Views)
If you want to "hide" a control, in your case the digital controls on the front panel you can use the "visible" property for the control.  So right click on the control, create a property node and select visible.  Then you can wire in booleans to show or hide the control.
(3,778 Views)
