Hide Pass/Fail Indicator
Hi everyone,
I have a pass/fail indicator on my front panel which I would like to hide during the measurement. End of the measurement it will show either PASS or FAIL. How can I hide this indicator and show it end of the test on the front panel?
Thanks for your help in advance,
Melih
(3,667 Views)
Just create a property node for it, select the "visible" property, and wire a TRUE or FALSE to it depending on the desired visibility. 🙂
(3,664 Views)
Thank you altenbach. Once you know it is easy! One more question: In my program I have flat squence structures and the indicator towards the end. Even though I set "visible" to FALSE at the begining when the program starts executing, the indicator shows right after it is invisible.
Any suggestions why this might be?
Thanks again,
Melih
(3,654 Views)
You probably have a dataflow issue. Can you attach your code?
For example in the attached simple code (LabVIEW 7.0), the indicator gets hidden for 3 seconds, then made visible and set to true.
Message Edited by altenbach on 11-18-2005 10:50 AM
(3,649 Views)
You're right. Sometimes you get lost in a structure. I moved the indicator to the following structure. It works fine and life is beautiful! Thanks again.
Melih
(3,637 Views)
