Hide Tabs at runtime
When hide Tabs at runtime, the right edge remain visible.
NXG style Tab ctrl.
LabVIEW 2019 SP1 32bit, Windows 7 Pro.
Test VI attached.
Work around: switch to the last tab before hide tabs.
George Zou
(2,681 Views)
I'm not too sure why it happens. However I found another programmatic workaround. Adding two more "PageSelVis" elements to the property node makes the edge disappear.
(2,573 Views)
That tag is awesome! "Jiggle_the_handle"
(2,566 Views)
That implies this is a redraw bug.
Actually, the invalidate rect already includes the right edge:
Minimize the window, and then resort it will make the right edge disappear.
George Zou
(2,550 Views)
