Hide all application windows without having to write code in each vi.
Hi all,
I have an application that contains numerous dialog-vis.
The application can run in "Normal" mode, in this mode the operator performs settings and selections.
The application can also run in "Batch", in this mode it receives through a file all the required selections and settings.
It runs automatically. All the windows of the various vi's pop-up and then pop-down automatically until it finishes.
In this "Batch" mode, I would like to have a solution to the problem of all windows poping up. I would like all windows to be hidden without
having to set this feature programatically in each vi in the application.
Thank you in advance
Shali
(3,050 Views)
Hi Shali,
As an idea what you could do is either maintain a list of all the vi's that you have open, or alternatively have a static list of vi's and then sequentially attempt to open a reference to each of them and use the show front panel property to hide each window.
Dave
David Clark
CLA | CTA
Genesee Technologies Ltd
Hampshire, England
(3,047 Views)
Hi Dave,
Thank you very much for your quick answer, that is also a good idea but:
The application running in "Batch",  is called by another program.
I am looking for a "strong" command, that can be done in the main application window or
by the calling program, maybe a windows command????
The application running in "Batch" is a uge application and is increasing all the time.
So I want a more "elegant" solution.
Of course, if I don't find it, i'll use yours.
Thanks again
Shali
(3,036 Views)
