Hide control based on radio button selection
I have 2 radio buttons a delete and a move. When the user selects the delete radio button I want to hide a path control. I know the controls can be hidden with the visible property node but how would I hide the controls based on the delete radio button selection?
I have not lost my mind, it's backed up on a disk somewhere
(3,034 Views)
You can create an event for the radio button (Value change) and hide the button if the value is "Delete". Radio button is an Enumerated data type, so when you use a case structure its quite easy.
(3,024 Views)
