Hide items in Case Structure
How can i hide the control indicators if not selected in the radio button. In the vi below, i want to hide the control indicators, difference, product, and quotient when i select addition in the radio button.
I want that only one control indicator displays while selecting a specific operation. When i press Addition,only,the Sum indicator must show up, while all the rest are hidden. operation.png
Message 1 of 9
(6,532 Views)
Check the Control/Indicator's Property node "Visible". Wiring False/True to the input terminal makes the Control/Indicator Hide/Unhide.
Message 2 of 9
(6,518 Views)
i didnt get your point, still finding a hard time
Message 3 of 9
(6,504 Views)
Right click the control>Create>Property Node>Visible. Drop this node and wire False to it and execute.
Message 4 of 9
(6,493 Views)
Accepted by topic author jamison.suade
Hi gjjude,
Probably you might be seeking for this solution. Check the attached VI.
Message 5 of 9
(6,482 Views)
Vij@y wrote:
Hi gjjude,
Additionally you could have done it in an Event structure.
Message 6 of 9
(6,474 Views)
P@Anand wrote:
Vij@y wrote:
Hi gjjude,
Exactly !  But I just want him to learn on his way and then thought of suggesting Event structure.
Message 7 of 9
(6,467 Views)
i cant see the attached VI
Vij@y wrote:
P@Anand wrote:
Vij@y wrote:
Hi gjjude,
Message 8 of 9
(6,458 Views)
Thanks i now get it
Message 9 of 9
(6,457 Views)
