Hide picture on panel
Hello.
I'm using Labview 8.5.1.
With my VI I want to make a PNG-Picture appear and disappear on demand. I use radiobuttons to show/hide different pictures. The picture to appear/disappear has a transparent background, so that one can see what picture(s) is(are) underneath. There's a permanent picture on the panel that always has to be visible.
I wasn't able to create a property node for a picture posted on the panel and the picture ring didn't work either.
I hope you can help me.
(3,490 Views)
Accepted by topic author questionmark
Why don't you use picture box? You have vis available to access .PNG files. In this way you can change pictures at runtime.
You will find these vis in Programming>>Graphic&sound>>graphics formats
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,472 Views)
Thank you very much!
Didn't know the picture box. I changed the frame of the picturebox to be transparent. Now it fits my taste 😄
(3,455 Views)
